Results 11 to 20 of 24
Thread: Will gq 4.2 diesel extractors fit gq 4.2 petrol
    Oct 2011
    Essendon
    Quote Originally Posted by Airstrike View Post
    Yep I took the gas off my TB42E..... after a slap and tickle I get 14.5 litre per 100k. Very happy.
    That's pretty darn good.....my TB42E gets about 25/100km over a weekend of low range and hwy cruising to get there....
    How did you get such a good result?
    I've not replaced my exhaust yet....what are you running on yours?
    Tap this.........
  2. #12
    Patrol Guru Morton's Avatar
    Sydney West
    that is awesome milage, I get 25-30 litres per 100kms, I run 35's on my Maverick
    2002 3L GU Patrol, 2" lift, 33's, snorkel, dual battery, sliders, DVD, bluetooth
  3. #13
    Patrol Guru Airstrike's Avatar
    Feb 2011
    Re: Will gq 4.2 diesel extractors fit gq 4.2 petrol
    Yep and I have 33 inch bighorns.
    Sent from my Boom Stick using Tapatalk 2
  4. #14
    Oct 2011
    Essendon
    What did you fiddle with to get that sort of consumption?
    Tip tip tip......tap tap tap....
  5. #15
    Feb 2011
    Hi mate a mix of different things. A new MAF and TPS. Had the engine tuned played with the AAC and used a ecutalk cable to factory reset the engine. So once all that done drives as good as the day it came out of the factory.
  6. #16
    Oct 2011
    Essendon
    I've been thinking about doing the exhaust and giving one of those ECUtalk modules a crack (or a Nistune board).
    What was your experience with the ECUtalk? Any good? How easy is it to advance timing etc?
  7. #17
    Feb 2011
    Hi mate I'm not using the module I'm using the laptop. VERY easy to use.
  8. #18
    Oct 2011
    Essendon
    So can you permanently adjust fuel mixture and timing via the laptop?
  9. #19
    Feb 2011
    Yes but not at speed...
  10. #20
    Oct 2011
    Essendon
    That's cool. How do I do that?
    Not the at speed bit..... LOL.
