Page 6 of 6 FirstFirst ... 456
Results 51 to 56 of 56
Thread: My blue bus....
  1. #51
    Re: My blue bus....
    thats not small there is at least double the capacity over the old one. Its bigger than my one.
    Yea although smaller its input is centre. So evenly displaced over the 6.
    A mate I built one for a while ago needed some 28ltrs in his 4.2 ford motor. Was a huge intake, ill see if I can find a pic of it.
    Owner of
    Westy's Accessories
    22 Post(s)
    Quote Originally Posted by Westy's Accessories View Post
    Owner of
    Westy's Accessories
    petrol and diesel ar different animals bigger isnt better for diesel, its only air, you need to fill that space, compress it and use it.
    96 GQ coil/Cab
    08 G6eT
  3. #53
    Re: My blue bus....
    Your right, bit the concept of having enough supply to allow maximum flow to each cylinder is the same.
    Owner of
    Westy's Accessories
    Advanced td42dan's Avatar
    Did the old manifold have a soot build up around the 4th and 5th cyclinder? Has it been pressure tested??
    have not take mine off yet, wont be doing it till next weekend. im away working.
  5. #55
    all im trying to acheive primaraly is to try and even out the heat from been directed at the centre two pistons, hopefully this will just limit the congestion of hot air compared to the standard intake manifold.....
  6. #56
    Re: My blue bus....
    Quote Originally Posted by td42dan View Post
    Yer fair enough. Keep us posted on how it goes.
    Owner of
    Westy's Accessories
