Results 1 to 10 of 13
Thread: Fitting a grab handle to the A pillar.
    Expert GQPorkroll's Avatar
    Hunter Valley NSW
    So, some time ago I bought an A pillar gauge pod. It will be housing a tacho and a volt meter for the auxiliary battery. The item came pre painted and with holes to use a grab handle,
    After a bit of looking, couldn't find one for a GQ so went for one off a GU. Knew there wouldn't be holes there in my pillar but figured I'd be able to do it somehow.
    Anyway, long story short, what I've decided to do is buy a blind screw rivet tool (called many things, possibly even a scrivet) and use that to put a thread inside the pillar capable of holding a handle strong enough to be used.
    I saw several people on the forum asking about this, but no one seemed to have a definitive answer, so I may take some photos and do a how-to tutorial if there is enough interest.
    As ill never really use the tool again, I wouldn't mind loaning it to members, as it's about $90 to buy the kit and a bit pricey for a one off thing so it may deter some people. I'd be happy to loan it for postage to and from and a small donation.
    Related, am I right in thinking that if I run a relay I will be able to turn the gauge on and off with my key, as I don't want to use a toggle switch and don't want to run the gauge all the time. (I'm thinking I'd run a ground wire, acc to switch, positive from the battery to power and load to the gauge).
    What size rivnut /nutsert are you planning to use ????
    Hunter Valley NSW
    The GU has a 5/16 UNF bolt holding the handle on, ill use metric, only because it's easier to get the scrivets in 8mm. I spoke with the supplier and a steel one should be more than strong enough to do what I want to do.
    AB has a DIY thread on installing nutserts without the tool. You should be able to get it done with forking out for th tool mate. Have a search around or pm AB. Sorry on my iPhone now so search sux.
    GQPorkroll (2nd February 2013)
    I'm on my phone too but type into the search ; how to install a nutsert without the tooling, hopefully that works bud.
  7. The Following User Says Thank You to AB For This Useful Post:
    Re: Fitting a grab handle to the A pillar.
    Here you go
    http://www.nissanpatrol.com.au/forum...ead.php?t=3531
    To tap, or not to tap: Well it's obviously tap because this is the signature hey!!!!!! Duh
  9. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    GQPorkroll (2nd February 2013), MudRunnerTD (2nd February 2013)
  10. #7
    Patrol Guru Morton's Avatar
    Sydney West
    I just read through all the different posts, this is going to save me heaps, I could use this on a few applications even in the building industry, I didnt know it existed but such a great idea, I learn something evey week on here, seriously you guys are 'da bomb', as my Kiwi mate just said "thats choice bro" lol
    2002 3L GU Patrol, 2" lift, 33's, snorkel, dual battery, sliders, DVD, bluetooth
  11. #8
    Most of my mates work or did work for Qantas/Ansett over the years they use the Rivnut tool all the time.
    very neat way of installing brackets etc and not looking out of place. My other 4x4 covered in these inserts
    Rivnut is the Aviation name, sort of like zip ties to cable ties, and who'd think a PK was a self tapping screw
  12. #9
    178 Post(s)
    Have used quite a few riv-nuts in my camper build. If planning to use a few getting the tool is worthwhile. The one I bought (like this) was fairly exy at $160, an air one to run off my compressor. Don't regret buying it for a moment. You do need to practice a bit with it before use though, if wrongly adjusted it can pull the threads out of the riv-nut, leaving the task of then removing the inserted riv-nut. Bugger of a job, especially in confined areas.
    Cuppa
  13. #10
    Hunter Valley NSW
    Yeah I assumed I would be able to compress it another way but decided at the end of the day the tool is probably fool safe and now I've had time to think about it, I can think of at least another 2 or 3 places I can use them, (thanks to whoever mentioned a snorkel, that's one job that requires 3!) so now I think about it, it's probably a very handy bit of kit to have.
    Offer will still stand for anyone who needs it to borrow the tool once I get it, though.
  14. The Following User Says Thank You to GQPorkroll For This Useful Post:
    MudRunnerTD (3rd February 2013)
