Results 1 to 10 of 12
Thread: To fiberglass or bog?
    Advanced brw1994's Avatar
    Nov 2012
    I made myself a fair dent in my sill on the weekend and want to know if its best to fiberglass out the bulk then bog or just bog the whole lot?
    Re: To fiberglass or bog?
    It's not a dent, it's character. So where did you add character to the body work?
    Don't stroke it, TAP it!!!!.....
    Drill and use pops to pull most of dent out minimum bog,
    Then make yourself some sliders
    brw1994 (29th January 2013)
    Nov 2012
    Yeh good idea three dogs.. I've already got some half made check the bar work thread.. And at toolangi somewhere up near the power lines
    Build a true slider not those ponsey pipe angled side steps.
    I'll put a pic here later for mounting option FYI, this style is more suited to the GQ than a GU
    brisbane
    2nd that I've come down hard on my sliders(tjm sliders with brush bars) and pushed them into the sill putting a huge dent the whole way along rather than just where the impact was make sure they are tough
    Nov 2012
    50m ID 4mm pipe, I'd hope so!
    Nov 2012
    And going to brace the mounts aswell with 6mm plate
  10. #9
    For a GQ this is a good mounting system, I had 12mm laser cut with holes in each corner that were tapped to 1/2" unc.
    then I had more plates cut to match the one I welded to the chassis, bolt them on then using anything you can as a support. milk crate etc.
    IMO I'd use thick walled steam pipe even 3" x 2" rhs on its side, pick up all your angles, then measure and cut supports and tack weld in place.
    I have them on my other 4x4 and you can lift the 4x4 off the groung via them. Mine were a more touring style. But easy to think outside the box
    2" pipe anything that wont squash on impact.
  11. The Following User Says Thank You to threedogs For This Useful Post:
  12. #10
    Nov 2012
    The only problem with that it Welding to the chassis and if I ever resell its not a dedicated rig
