Results 1 to 10 of 12
Thread: Leaking brake booster
    Expert MS29431's Avatar
    Nov 2010
    NTH EAST SUBURBS MELBOURNE
    Question Leaking brake booster
    My booster is leaking pretty bad...... Still hard pedal stop's well but is leaking fluild wreaking paint etc... Can somone tell me how hard they are to change (is there anything to look out for) or a place in vic that i can get a good reco or new one from????
    Benarkin QLD
    Is the master cylinder leaking fresh fluid ???
    From the pics doesnt look to fresh,paint already lifted
    Looks like typical early patrol pic
    How much fluid are you goin thru ??
    Top up daily,weekly,monthly ect
    Options are,
    Either buy a kit and rebuild the brake master cylinder yourself
    Pay someone to do above
    Buy a new master cylinder and fit yourself or pay someone to fit
    Either way the full brake system will need a rebleed
    Its not a 5 min job
    Cost,
    Well that depends on ,parts and labour costs,and what you can or cant do
  3. The Following User Says Thank You to MQ MAD For This Useful Post:
    MS29431 (24th January 2011)
    Nov 2010
    I had drama's with a broken cap a few years back hence the old lifted paint,But it is leaking fresh fluid, I've found that i'm refilling it once a fortnite or so, Got no prob's giving it a crack (changing the whole unit that is) i'll get a whole new master just wondering if there's any tips for things i need to do or lookout for, Thanks for your input its greatly appreciated... MS
    It's a fairly straight forward job, make sure you have a good set of pipe spanners the right size (pipe spanners llok like ring spanners with a small section of the ring cut out to go over the pipe).
    Remove as much brake fluid from the reservoir as you can.
    Remove the brake lines from the master cylinder.
    Undo the bolts holding the cylinder to the booster.
    Fit the new cylinder and reconnect brake lines.
    Bleed the brakes.
    Easy.
    Tony
  6. The Following User Says Thank You to YNOT For This Useful Post:
    Nov 2010
    Sweet, sounds pretty strait forward ive got pipe spanners etc thanks for your info much much appreciated.... I've worked on all type's of equipment over the years but never 4X4's i guess its just a matter of having the confidence ind info to give it a go Thanks again mate... MS
    Benarkin QLD
    Yeah fairly straight forward as Tony mentions
    Just have a container of water handy
    If ya get any brake fluid on the paint work
    Wash off straight away
  9. The Following User Says Thank You to MQ MAD For This Useful Post:
    MS29431 (25th January 2011)
  10. #7
    Banned
    A few more Tips.
    Brake fluid can be removed from the reservoir by using a rag (it will soak into it)
    Only by good brand pipe spanners as the cheaper ones will do more harm than good, not to mention damage.
  11. The Following User Says Thank You to patch697 For This Useful Post:
  12. #8
    Nov 2010
    The old Sidchrome's will do the trick, Somthings, Like tools you can't afford to cheap out on.
  13. The Following User Says Thank You to MS29431 For This Useful Post:
    patch697 (25th January 2011)
  14. #9
    Banned
    onya mate........
  15. The Following User Says Thank You to patch697 For This Useful Post:
  16. #10
    Jul 2010
    Waterford West Qld
    Another two tips, keep water away from breathholes on reseviors, and use the correct type brake fluid for you model patrol.
  17. The Following User Says Thank You to Finly Owner For This Useful Post:
    MS29431 (26th January 2011)
