G'day, So I finally got around to putting my new gear on my patrol (gq 1990)
I installed a GU steering box, a heavy duty draglink with GU tie rod on one end (for the GU steering box) and GQ tierod end on the other, With a new RTC steering dampner.
When I turn the steering full lock to the right, It rubs up against the panhard rod (which I beleive what it is) and I have no clue why it would be doing this. I thought about spinning the bolt around but it will still rub, Thanks for any help you guys can give me or any suggestions
. Because you have a GU tie rod end you can't flip it so you must but the other end and fit it to the left side.
