Results 1 to 10 of 17
Thread: hazard light failer.
    Dec 2012
    Sunbury
    G'day guys/gals.
    I've just finished the dummie tail light mod on my 98 gu,works and looks great.
    Unfortunatly my hazard lights seem to have stopped working.they worked after the mod when i tested all the lights but seem to have stopped a day later,all the indicators work and all the indicator lights work with central locking.(flash once for lock and 4 times for open)
    I've checked the fuze under the bonet 10amp and that was not blown
    Would it be a relay( dont know where that is) or something else that i dont know about?
    Any advice greatly appreciated.
    Steve.
    I was told that they would blow as fuse was weak if towing and used your hazard. I'd be re checking your connections with a multi meter,
    Check all new earths as well
    Dec 2012
    Sunbury
    Ive towed a trailer before and had to use hazards without a prob,what i will do after i get this sorted will be to use led globes to take a bit of pressure of the fuse,
    do you happen to know where the hazard relay is located?
    all joints were soldered and the earth is on bare metal.
    On the GU its under bonnet in front of driver, I already have all globes either LED or HID.
    Lost pics of globes but only needed 50ohm resistor on every corner for indicators
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    The GUs use the same flasher unit (relay) for the hazards and indicators. If your indicators are working I don't think your flasher unit is the problem.
    Are your sure you checked the correct fuse under the bonnet? replace it with a 15 amp fuse anyway.
    If the fuse is not blown you may have a problem with your hazard light switch, try pressing the hazard switch 20 or so times and see if it starts working.
  6. #6
    Hardcore jack's Avatar
    Ballarat Area
    26 Post(s)
    Hi Mate,
    I've done this mod and it's always the hazard light fuse that blows, replace it with a 15A one and it will work fine (even towing).
    Jack
    2024 Isuzu MUX
  7. #7
    Dec 2012
    Sunbury
    Yender,first thing ill do when i get back to the car is press hazard light button 20 or so times and see if thats the culprit.
    And im reasonably confident i checked the right fuse according to the fuse cover diagram.its a 10 amp fuse.
    thanks.
  8. #8
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    I would replace the hazard light fuse first.
  9. #9
    Dec 2012
    Sunbury
    Apollofish/Yenor
    Thanks for the reply,Im hesitant to just drop a larger fuse untill i know what the problem is.Reading other posts with simular problems they advise caution when upping the size of a fuse.
    Steve.
  10. #10
    Dec 2012
    Sunbury
    @Yendor,when i get home from work tonight ill replace the 10 amp fuse thats in there atm with another 10amp just incase the fuse did blow and im blind and cant see it.that will at least give me an indication if its that fuse or not.
