Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Patrol front right end going "DOOONG" over small bumps....vague I know right?
    Everytime mine is up on the hoist we go over all the bushes etc with a large screwdriver, to check for any movement. its not often but just have access to hoist
  2. The Following User Says Thank You to threedogs For This Useful Post:
    ozzymalone (14th January 2013)
  3. #12
    Expert Benno7's Avatar
    Nov 2010
    Quote Originally Posted by ozzymalone View Post
    Hey Benno how did you figure it was the link? was it visibly stuffed/cracked, etc. Pretty sure you can go without the front swaybar in gu's without negative consequences but would love to hear some feedback.
    I was checking every thing to try and find the noise and just looking at the sway bar one of the ends looked like it was sitting funny so i removed it and found it was very badly worn.
  4. The Following User Says Thank You to Benno7 For This Useful Post:
    ozzymalone (15th January 2013)
  5. #13
    Legendary happygu's Avatar
    OzzyMalone,
    I know the noise you are talking about, as I have had it in my previous vehicle.
    Normally it is the passenger front side that does it, not the drivers side front, and I have always thought it to be the spring binding in the tower.
    I have put a 5mm Polyethelene pad, on the bottom, and checked and taped the top rubber so it sits in the right position, and I haven't had the noise since.
    Mic
  6. The Following User Says Thank You to happygu For This Useful Post:
  7. #14
    brisbane
    I'm with happy on this one mine is doing the same and has for a long time now I've just left it as it doesn't bother me as long as I know what it is lol
  8. The Following User Says Thank You to megatexture For This Useful Post:
  9. #15
    Expert BearGUST's Avatar
    Apr 2011
    Mornington Peninsula
    I had a similar issue which was the same thing as Westys. I ended up parking the car on an angle and getting my old man to rock the car, I could feel the clunk through the radius arm. Tightened the sh1t out of it, all good since.
    GUIII ZD30 Manual Wagon, OME 2" lift, 33" BFG AT's, Snorkel, Chip, 3" Redback Exh, Dual Batts, etc.
    KEEP OUR TRACKS LITTER FREE!
  10. The Following User Says Thank You to BearGUST For This Useful Post:
  11. #16
    Go over every nut and bolt on the front axle. As mentioned mine flogged out, wasn't that bad so I changed out the loose bolt and all is good now.
    Owner of
    Westy's Accessories
  12. The Following User Says Thank You to BigRAWesty For This Useful Post:
  13. #17
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    let us know how you go as I have the same thing in the driver's side. have no friggen idea what I am looking for but will be pushing, pulling, poking and prodding whatever i can find under there and I know it won't be the missus o_O
    www.swat4x4.com
  14. The Following User Says Thank You to oncedisturbed For This Useful Post:
