Results 1 to 10 of 17
Thread: Patrol front right end going "DOOONG" over small bumps....vague I know right?
    Expert ozzymalone's Avatar
    Aspley, QLD
    Hi all....Just got back from my Chrissy hiatus and went for a pot around in the troll' and realized the front right end is emitting a hollow/metallic like "dong" sound whenever going over bumps (during rebound i believe)....even speed humps in car parks at slow speeds. Thinking its just the rubber bumbers over the coil....does this sound right or am i looking in the wrong place.....opinions welcomed.
    And I know my description is a tad vague.....but you saw who started this thread right!?! You should surely expect nothing less.
    SPEED METAL NEVER WENT AWAY>>>>> ONLY OUR HEARING DID!!!
    Stuffed shocks???? Push down on each corner ,should go down and up once only anymore just riding on coils/leaves
    ozzymalone (14th January 2013)
    334 Post(s)
    I reckon a Front Panard Bush, a Tie Rod end or a front Radius arm bush for sure.
    Aspley, QLD
    Hey threedogs....hope you're well on the mend mate its been a while. SO if i get the missus to push down the front end firmly there should only be one clear down and up stroke? , and no further bouncing at all? .....Ta
    Expert Benno7's Avatar
    Nov 2010
    I had a similar thing happening with my GQ It drove me nuts. It ended up being the front sway bar link one side was stuffed. so I removed the sway bar problem solved.
  7. The Following User Says Thank You to Benno7 For This Useful Post:
    476 Post(s)
    Check where the radius arms mount, Westys had a similar issue and the bolts were flogged out and the arm was "floating". He did a write on this somewhere here. I have the same issue but its really quiet and haven't bothered to look for it yet.
    But check the shocker bushes too, the rear of mine did a loud noise like this and I discovered the bushes were almost non existent. Replaced them and is all good at the rear now.
    Quote Originally Posted by Benno7 View Post
    Actually try this. Remove the sway bar. Come to think of it, mine has not done it since I have removed my sway bar when I did the clutch...I must get around to putting that back in one day.
  10. #7
    Aspley, QLD
    Hey Benno how did you figure it was the link? was it visibly stuffed/cracked, etc. Pretty sure you can go without the front swaybar in gu's without negative consequences but would love to hear some feedback.
  11. #8
    334 Post(s)
    I dont have a Front Sway bar on the GUIV and have not had one fitted for at least 4 years. It is my daily and my Tourer and i simply can not think of a reason for refitting it., I have a 3" lift and Drop boxes though and it is well planted.
  12. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  13. #9
    476 Post(s)
    The only one reason I can think of is insurance. I cannot afford to run the risk of being denied a claim if I was to ever have a stack and they inspected the car and found no sway bar. Otherwise I would leave it off...
  15. #10
    Aspley, QLD
    Have just done the front and rear radius arm bushes so hopefully thats not the verdict sso will inspect all mentioned areas this arvo hopefully......thanks all. Appreciate it!
