Results 1 to 4 of 4
Thread: remote locking
    Dec 2012
    remote locking
    anyone know about the remote locking frm the key have changed the batts but still not working ? patrol 2008 gu
    Expert WYLD333's Avatar
    Nov 2012
    Pakenham
    Id say ur remote is nackered, i had the same not long ago went 2 nissan got a new remote and i programmed it. Was around $200 frm memory
  3. The Following User Says Thank You to WYLD333 For This Useful Post:
    shaunsdogdog (17th December 2012)
    Nov 2012
    Pakenham
    Also just cheak that ur new battery is good by running a meter over it and also make sure that the terminals are clean n have a good connection. If all above is good its remote time
  5. The Following User Says Thank You to WYLD333 For This Useful Post:
    Dec 2012
    Ok tell me after replacing the battery your remote light turn on when you press any button or lock/unlock button? If its turns on the light then you can try this for temporary. You can hold the button for 20 - 30 secs. I know its works because I also faced this kind of situation. Good Luck
