Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 49
Thread: iPad Mapping setup
  1. #31
    Patrol Guru Lonicus's Avatar
    Tewantin QLD
    I have an iPad, without 3G. If I ever need to access the 'net away from home I just set up my iPhone as a wifi hotspot & connect the iPad through it.
    Would that work with the maps or is it best to have a 3G iPad?
  2. #32
    Expert stevogq's Avatar
    behind you
    hehe i use mine in my boat for gps marks in PPB best thing ever!! i use navionics its got marine maps for the whole aus want to dl a gps for 4wd but you really need to use telstra because they got better 3g reception
  3. The Following User Says Thank You to stevogq For This Useful Post:
    Lonicus (7th November 2012)
  4. #33
    Quote Originally Posted by Lonicus View Post
    I think you can buy a GPS receiver for them mate.
  5. The Following User Says Thank You to AB For This Useful Post:
  6. #34
    Tewantin QLD
    Thanks AB. The navionics sounds good too Stevo.
  7. #35
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    For the Ipad's without GPS / 3G ability, there is a GPS receiver that plugs into the charging port on the Ipad. It is made by Bad Elf and can be purchased at their website. From all reports I have read they are supposed to be very good little receivers.
    It also does not run off any PHONE COVERAGE, none of the mapping apps run off phone service unless you are accessing "Online Maps".
    www.swat4x4.com
  8. The Following User Says Thank You to oncedisturbed For This Useful Post:
    Lonicus (8th November 2012)
  9. #36
    behind you
    yeah lonicus its great if your a fisherman got all my snapper holes tagged
  10. The Following User Says Thank You to stevogq For This Useful Post:
  11. #37
    Beginner Honky's Avatar
    Dec 2012
    Weipa FNQ
    I've been onto this for a while, ever since i bought one for the mrs for xmas and she let me "play" with it. Half hour later, it's jailbroken, loaded with 4 GPS apps and there's a windscreen mount bracket coming in the mail. What people have said before is right though. Only cellular capable Ipads have the GPS chip. If yours is a WIFI only then it will need an add on.
    To be honest, i never go 4wding without this thing now. It's way too handy not to have on board, even if the little girl in the back is watching movies on it most of the time.
    For my 2 cents, these are my choice for best mapping apps that i use all the time.
    Motion X GPS HD
    Good because you can cache google / bing satellite maps and track your position on them. This is really handy for those little tracks that show up on the satellite image but don't show up on any other map. Plus it gives you a better idea of terrain, creek lines etc. I have found some really good camping spots just following tracks with this thing.
    Hema 4WD Maps
    Definitely one of the best out there for standard paper map type tracking. There's enough detail between the different maps on offer that if a track isn't shown on one, it's shown on the other as you go through the layers and zoom in. If you get lost out bush with this one, then you should stay at home and watch 4wding on tv. Pricey app though, but worth it
    Tom Tom Aus
    Great street map app that's exactly like using a navigator in your car, just this one has a much bigger screen. Pricey too, but cheaper than buying a second unit if you have to nav out of the city to get to that camping spot out bush.
    Navionics Gold
    For 49 bucks this is one of the best nav apps for boaties. I have a split screen in my boat, and with this mounted on my dash it gives me a full marine chart, and i can use my sounder as a proper sounder. Really good too, it's exactly the same as the map my plotter uses but heaps cheaper.
    Also the mount i use is this one:
    http://www.arkon.com/tablet-accessor...eld-mount.html
    Gives plenty of length and i just secure it to the front window and strap it onto the dash with a bit of velcro tape. Gives me plenty of stability and the mrs can swivel it around to change maps etc so i don't have to do it. Got mine for 49 bucks off ebay i think. Well worth it.
    Keep one eye on your enemies, keep two eyes on your mates
  12. The Following User Says Thank You to Honky For This Useful Post:
    MudRunnerTD (20th February 2013)
  13. #38
    Patrol God Stropp's Avatar
    38 Post(s)
    thanks for the link Honky, just bought the tab178, plan is to mount it inside the flip up centre cavity on the gu and just use it when i need it or fold the door down when im not using, will see how it works out when i get it, ebay $33 au delivered. cheers Stropp
  14. #39
    brisbane
    heres my set up theres no movement in it at all and ive got a twin usb plug in the compartment also works a treat and when closed you can see the plugs or mounting location and theres no permanant floor mounting to get in the way
  15. The Following User Says Thank You to megatexture For This Useful Post:
    Stropp (8th December 2012)
  16. #40
    38 Post(s)
    looks good mate thats exactly what i want to do. cheers
