Results 11 to 20 of 23
Thread: K&N Air Filter in a 3L 05 GUIV (NON CRD)
    22 Post(s)
    Quote Originally Posted by happygtu View Post
    Just don't over oil it, or you will end up with your MAF sensor coated in oil, and then you run the risk of the sensor giving incorrect readings ....... it could then even help it go Kaboom!!
    I won't use one, as it is hard to quantify when it is over or under oiled.
    its not that hard at all. if you let it sit as per the instructions, if sections of the element are a lighter colour its under oiled. The excess oil will drain off.
    96 GQ coil/Cab
    08 G6eT
  2. #12
    Dwellingup, WA
    I am happy with the balance of information provided on this thread. Have already had a head ache with Thelmas MAF sensor so I have no desire to go down that path again so will be applying the 'less is more' phylosophy when servicing the filter and if not happy, will put an original back in until the K&N is adequately drained and the same colour all over. Will also keep the original handy J.I.C. Thanks Ben.
    Are you ready for Christmas?
  3. #13
    Legendary happygu's Avatar
    Thanks Ben-e-boy.... I should have quantified that I use one on my motorbike and I am happy to use it for that purpose, and even know how to oil it too.
    It is hard to know who you are talking too at the other end of the internet, so sometimes it is best to give the information that the majority seem to think is the best solution. I have heard ( not seen ) of quite a few oil coated MAF's and their particular owners with problems...
    Mic
  4. #14
    Expert Dave_H's Avatar
    Nov 2013
    Whyalla S.A
    I have just put one one of these filters in my 08crd and now i have just found this thread which has me a little concerned about the MAF. I already knew about the filter letting in more dust but
    I was just going to carry a genuine nissan filter with me and change it over when we hit the dirt.
    Has anyone got any more info since the last post in 2012???
    2008 GU6 ST 3.0 CRD Auto, 2" Lift, ARB Bullbar, IPF Spotties, Side Steps, Maxxis 980 A/T, Roof Rack.....................
  5. #15
    Western suburbs of Melbourne
    11 Post(s)
    Quote Originally Posted by Dave_H View Post
    I have just put one one of these filters in my 08crd and now i have just found this thread which has me a little concerned about the MAF. I already knew about the filter letting in more dust but I was just going to carry a genuine nissan filter with me and change it over when we hit the dirt. Has anyone got any more info since the last post in 2012???
    I've had one in mine since the exhaust went on. (Basically from new) and haven't had a problem with it. (YET LOL)
    I do have two filter, one spare and just change and clean and re-oil after dusty trips.
  6. The Following User Says Thank You to MEGOMONSTER For This Useful Post:
    Dave_H (7th May 2014)
  7. #16
    476 Post(s)
    Got one in my Di. No issues. And you wont see issues unless you over oil it. I use the spray on oil and that makes it very easy to apply and NOT over oil it.
    Dave_H (8th May 2014)
  9. #17
    Patrol Freak kevin07's Avatar
    georges hall
    when I bought my troll it had one in it now it sits lonely in a box on the shelf
    13 y62 the beast that burbles
  10. #18
    Nov 2013
    Whyalla S.A
    Not a fan Kevin????
  11. #19
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    The trick is to not wash them too regularly. I've heard from several mechanics that for any air filter to be effective, require a certain amount of usage(ie dust and crap) to block the large openings in the filter.
    The trick to high mileage engines is regular oil changes and not so regular air filter changes as dust does cause considerable wear to the engines internals.
  12. The Following User Says Thank You to Parksy For This Useful Post:
    Dave_H (9th May 2014)
  13. #20
    georges hall
    Not a fan Kevin????
    no not a fan I feel why put something in my motor that may hurt it and theres plenty of info here to suggest that it could happen.
  14. The Following User Says Thank You to kevin07 For This Useful Post:
