Results 1 to 3 of 3
Thread: power aerial
    Expert benno77gu's Avatar
    Nov 2012
    tumut nsw
    power aerial
    hi fellas, i was wondering if anyone has changed the aerial in their gu wagon any hints or tips looks like a bugger of a job, thanks
    01 gu td4.2t wagon factory turbo 2" lift, 3" exhaust,snorkel,awning,uhf,egt & boost gauges,16"black round hole dynamic rims with 285 bighorns with more to come, ,air compressor,rear led work lights,winch, ready to fit up
    Expert BearGUST's Avatar
    Apr 2011
    Mornington Peninsula
    Hey Benno, do you need to replace the whole assembly or just the mast?
    If its just a mast you should be able to just remove the chrome nut at the base of the aerial mast and use the motor to drive the old mast & rope out, then use it to pull the new one in.
    If you need to do the whole assembly you'll need to pull the inner guard out which is pretty easy too.
    GUIII ZD30 Manual Wagon, OME 2" lift, 33" BFG AT's, Snorkel, Chip, 3" Redback Exh, Dual Batts, etc.
    KEEP OUR TRACKS LITTER FREE!
  3. The Following 2 Users Say Thank You to BearGUST For This Useful Post:
    benno77gu (26th November 2012), jman69 (22nd December 2012)
    477 Post(s)
    Yeah not hard to do. The mast on mine never went right down since I bought the car. I assumed that how they were until I was told otherwise. I took the whole thing out, by removing the inner guard then the whole thing is easy to get too and remove, I then pulled mine right apart, clean it out and now it works like a new one.
    I reckon it would be quite hard to get the new rope in the motor without pulling it apart. As the rope curls up and if the teeth on the rope aren't exact you might end up destroying the teeth...
