Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 70
Thread: 2" lift quote differences
  1. #31
    Have a look at the 4" flexi coil, your 4x4 will only look 2" high but off road it'll be a weapon. wish I knew all this before I fitted 2" EFS but happy with the stance just wish it was softer, but told it's not possible with all accessories fitted. Think mudrunner has them fitted only heard good things
  2. #32
    Expert Diesel-Mate's Avatar
    Gold Coast
    Mate give suspension stuff a look. All you will need for a 2" lift is just springs and that's it. No need for caster correction or extended swaybar links or extended shocks ect. They guy from suspension stuff sells hd 2" lift springs at $350 for a set of 4. You can't do any better.
    TD42 turbo GQ - ironman snorkel - 4 inch flexy coils - 6" shocks - 3" straight exhaust - pyro and boost gauges in A pillar- uhf - winch - sunraisers - Bluetooth - spotties - front lokka
  3. #33
    Western suburbs of Melbourne
    11 Post(s)
    I read on here some people have a 2" lift on their GU and have adjustable panhard rods. What are they and what do they do.
  4. #34
    Patrol God Stropp's Avatar
    37 Post(s)
    Mego you don't need adjustable pan hards with 2" lift just with 3" or higher, when they get to 3" or higher the diff can move over and one wheel will stick out of the wheel arch, the adjustable pan hards will pull the whole setup back to centre.
  5. The Following User Says Thank You to Stropp For This Useful Post:
    MEGOMONSTER (6th May 2013)
  6. #35
    11 Post(s)
    I was just reading it, and thought I'd hijack my own thread, instead of starting a new one to just find out what and why Cheers and thanks.
  7. #36
    Apr 2013
    Mount Nasura
    Anyone had any experiance with the Bluemax gear from SSA?
    Looks resonabley priced.
  8. #37
    mackay
    had a set of bluemax on my runner they are priced higer than what they are worth, only did about 5000 km and they where shot to hell
  9. #38
    Expert graeme1969's Avatar
    Jun 2013
    Wesley Vale, Tas
    It seems everyone in this and other threads have opinions on which brands they like for spings and shocks, but on the other side of the coin whcih brands would you definately steer away from?
  10. #39
    Ballarat, Vic
    176 Post(s)
    My Lovells GVM upgrade/2" lift kit included castor correction bushes.
    Cuppa
  11. #40
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    The 2" lift for shocks and springs start about $600 and go well past $2000. I'm guessing the high end $ are not necessary!!
    1999 GU 4500 dual fuel
    Il dado è tratto
