Results 1 to 3 of 3
Thread: My ZD30 wont start!
    NE Victoria
    My ZD30 wont start!
    '02 ZD30 auto, starts mucking up! First warning, ignition on, lots of relays go click 'n clunk (normal!), but no instruments/warning lights! No starter motor engaging! Call RACV, after having done lots of fault finding, myself. RACV man looks and does everything I just did. By fluke, car starts. He did not know what he did. "We have an intermittent gremlin!"
    So off I drive. The gremlin re-appeared. Same modus operandi: no start. Then I tapped the 3 relays on top of the internal fuse box. Turns out these relays control ignition, air-con, and accessories. AND all 3 relays are the same. So next time the gremlin popped up. I changed/swapped all the relays around. Hey presto: it starts!
    Got a quote for 1 relay from local; Nissan dealer $133. Went to auto-elec store. Same relay $6.50! It a fairly universal high-current after-market automotive relay.
    My tip. Keep 1 in your spares. Just in case your car, air or accessories stop!
  2. The Following 4 Users Say Thank You to crutchy26 For This Useful Post:
    choppie (18th November 2012), Sir Roofy (19th November 2012), steve4377 (18th November 2012), Yendor (17th November 2012)
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Thank's for the heads up mate.
    Nissan sure know how to charge for a relay.
    Glad you got it sorted so cheaply.
    Maroochydore, SunShine Coast.
    Good pickup crutchy, glad you got it sorted easy and not much coin.
    Drive is 04 DX wagon, 165Ks, Dual Batts, 12000kg Warn in steel bar, Snorkel, Xray 220 Hid Spots, Cruise, digital EGT, Draws in back with power box, 40Ltr Waeco for the essentuals
