Results 1 to 10 of 13
Thread: which suspension ???
    Expert benno77gu's Avatar
    Nov 2012
    tumut nsw
    Hi i am going to fit 2" suspenion to my gu wagon i do moderate 4wding trails and a few hill climbs i was wondering what is the best value for money eg iron man, king springs, dobinsons or any brands, any help,advice or opinions will be greatly appreciated cheers
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Hear that? That was the can of worms being opened!!! lol
    Heaps of threads on this very topic mate, and whilst everyone has their view, it's a matter of assessing what you're after, what you do, and what you can afford - from there, there's a wealth of choice.
    Never had them, however the OME gear gets a good wrap whenever this conversation kicks off. 2" flexi coils from suspension stuff or a range of others perform well on and off road.
    No doubt others will weigh in on this one to assist.
    .......... TPC's Avatar
    63 Post(s)
    I've always had OME and they have worked well for me, they seem to match the springs and shocks well to the setup or your 4wd.
    Ive had a OME (old man emu) 2" kit for 30,000 now and they are tough..
    But to me they are stiff.. I've been told they do a couple of different strength of shocks and seem to hand out the stiff ones with the kit.
    A couple of people request the comfort shock. It allows a little body roll on hard corners but have been told there a dream ride..
    A basic 2" kit from OME is around the $1000 mark.
    Don't stress about the castor correction bushes or gearbox drop plates if your in a LWB nissan. There not really needed.
    Keep us informed whichever way you go.
    Owner of
    Westy's Accessories
    mines a gu stii duel fueler and we just had ome 2'' put in.nitro chargersx 4 and coils to suit roof rack and fridge and rear draws,all of wich are not fitted yet so ride is firm.we just did an 8 day stint from broadford to jenolan caves on tar so got freeway and lots of bitumen tight corners,then over blue mountains to gosford then down coast to bega then inland to jindabyne,some dirt and corragations then to corryong and down to anglers rest and back to wodonga to broadford.all in all we got the lot except for lowrange hillclimbs.we only had about 200kgs of gear and the only place susp felt too hard was on big potholes but,as i said,accesories are not fitted yet so i cant complain.no excessive body roll and wagon goes about 2030mm high with standard wheel size.arb bendigo supplied and fitted 4 nitrocharger shock and 4x heavy coils and a new ome steering stabilizer and did a 500km check on ride height and bolt and nut check for $1530 inc gst.a kit was fitted to stabiliser bar as well.No castor kit was needed.all up im happy with job.
  6. The Following User Says Thank You to danielhobby For This Useful Post:
    MudRunnerTD (9th November 2012)
    Legendary happygu's Avatar
    You can't go wrong with most of the major brands.
    Most will recommend OME, as will I, as I have had them in the past and they were great.
    My most favoured and longest used combination ( 13 or so years ) has been the Kings Springs and Koni shocks, which have always proved to be excellent.
    At present I am running OME front coils with Dobinson Rears, with Koni 88's. Works OK too.
  8. #7
    Legendary big_fletch's Avatar
    Oct 2010
    Tatura VIC
    Best bet would be to find some patrols with 2" lifts (most common size) and take them for a drive if able.. Will be hard to pick otherwise as everyone has a different idea of what they want the ride to be.. OME is a excellent brand (sold by ARB), Tough Dog, Dobinson's, Koni, Bilstien ect are all very well known and reliable brands.. I personally use RidePro with ROX Shocks and i love it
    Fletcha
    Qualified Auto-Electrician
    Apprentice Sparky
    Dont own a Patrol or any 4WD at the moment, hopefully will change into the future
  9. #8
    Here is my 2" OME kit
    http://www.nissanpatrol.com.au/forum...948#post291948
    Owner of
    Westy's Accessories
    Nov 2012
    tumut nsw
    thanks fellas i have priced a few kits OME $1260 iron man $900 and another iron man $742 dobinsons $800 i am leaning towards the iron man performance kit $742 (wife starting to complain spending to much) are sway bar extensions needed or the rear brake bias bracket cheers
  11. #10
    Expert Steve4wdin's Avatar
    Feb 2012
    Western Sydney
    Heres my 2c worth. I run Dobinson springs and koni shocks . The ride is superb while handling the wieght of dual battery, steel bar and winch on front and draws and 80lt fridge in back. Yes you should put on sway bar extension brackets. ARB sell them for about $30.00. It just brings rear sway bay back up vertical. You shouldn`t need caster correction on the front.
    Steve
