Results 1 to 10 of 17
Thread: Introductions and Queries
    Bayswater WA
    Greetings all,
    Id like to introduce myself and recently acquired vehicle before getting stuck into the forum discussions but first Id like to thank the contributing members of this site for the invaluable information and knowledge that has been shared throughout the forum which ultimately enabled me to make a far more informed decision on the pros, cons, strengths and weaknesses of fourwheel drives on the market (in particular patrols) within my price range. Thanks to the experiences and wisdom of people in this forum, I was able to avoid some of the more problematic engines and have ended up with a rig I am stoked with.
    I’ve gotten hold of a ’98 GU 4.2 Turbo Diesel DX Wagon. Mods are as follows:
    Safari Turbo, Intercooler and Snorkel
    2.5” dump pipe and exhaust
    Heavy-duty Clutch
    4 Core Radiator
    ARB Air Lockers, Compressor, Bull Bar, Side Steps and Paratus seats
    Old Man Emu Springs with 2” lift, LTR shockies and steering damper
    Poly airbags in rear springs
    Outbacker Drawers with Fridge Slide and Ceiling mounted Centre Console with 2x CBs
    30L Water Bladder
    IPF spotties
    Dual batteries
    7x power outlets
    16R BFG All Terrains
    The motor is brand new having only done 12000kms but is to my dismay, exactly the same as the previous one (non turbo block). As I understand, this block is much weaker than the factory turbo block (and has lighter pistons?) Any advice/views on this would be most appreciated.
    I noticed a lot of black smoke under any load or acceleration and some pretty horrific fuel consumption and so thought it best get a dyno tune from United here in Perth. This resulted in a lessening of the fuel mixture and subsequent reduction in power and torque to the tune of 14kw and 40nm (96kw total ☹) with not much better fuel economy (900kms driving at between 95 & 100km/h) and still some black smoke under acceleration. The manual tells me I have a 90 + 40l tank set up, the previous owner says 96 + 30, much of a muchness. Ive got a feeling that my fuel gauge could be out resulting in the light coming on much earlier than required. I wanted to test this theory by running it dry to see what sort of mileage I get but being new to diesel motors, don’t want to attempt this if I’ll have to bleed the system as a result. Any thoughts?
    Ive been an avid outdoors enthusiast for years, particularly enjoying camping, fishing and trekking but have only now managed to secure my own rig. My favourite spot at the moment is Cape Range National Park – I get up there for a bit of camping and fishing 2 – 3 times a year having recently returned (very nice drive at the moment).
    Being a rookie to the 4WD scene, I will not be able to offer much technical assistance in the short term but as I intend to do the majority of work on my vehicle myself I expect this will change in the coming years. A pleasure to meet you all and thanks again for the invaluable information provided on this site.
    Cheers,
    Wayne
    Perth WA
    63 Post(s)
    Welcome Wayne, enjoy the forum mate and thanks heaps for the great intro.
    Being a rookie it is a good idea to do a training course and/or join a 4WD Club, it just so happens that I know of a Bloody Great Patrol club in Perth http://www.nissanpatrol.com.au/forum...atrol-Club-Inc
    Welcome to the forum Wayne, great intro.
    As far as I know TD42 and TD42T used the same engine block and head. The only difference being a few extra holes were drilled and tapped to get oil and water feeds for the turbo model. GQ silver top (silver rocker cover) had heavier pistons than the later GU black top engines. Unless you plan to turn the boost right up to go racing you won't have any problems with your black top engine. They are still good for significantly more power than standard with complete reliabillity.
    I suggest you fit boost and pyro (exhaust temp) gauges ASAP if you don't already have them. These 2 guages will tell you a lot about what your engine is doing and how well it is tuned.
    I agree with Dogman (also Wayne) that the best thing you can do is join a 4WD club and do their driver training course.
    Your idea to do most of the work on the car yourself is excellent, not only will you save a lot of money but you will learn a lot about your car at the same time. If you get stuck or if there is any thing you are not sure about, just jump on here and ask any questions you want.
    Tony
  4. The Following User Says Thank You to YNOT For This Useful Post:
    Mr Trol (8th January 2011)
    Patrol God wildgu6's Avatar
    Sep 2010
    Adelaide S.A
    Hi Wayne, Welcome aboard the Trol express,
    Simply the best forum around. Heaps of handy information as you have already found out.
    Great bunch of people with a s*** load of knowledge, experience and adventures to share.
    Plenty of good laughs along the way as well and lots of pics to check out. We love em
    Great intro buddy and soundslike a great rig you have got yourself. Well done.
    Good luck, Welcome aboard and Enjoy the ride
    Hope you have a great 2011.
    Happy trekin buddy, stay safe
    Cheers Pete
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    Welcome Wayne to the forum. May you have many hours of reading.
    Hi Wayne.
    Welcome to the forum mate. Sounds like you have picked yourself up a great car mate. No Doubt about it, you have bought well.
    Hmmm? Sounds like the previous owner had the fuel turned right up, if you de-tuned it on a Dyno to 97kw then you should be really really happy with that. My GU IV TD42Ti gets about 97kw then i turned the boost back a turn and am likely getting 92kw. So be very happy with 97kw i reckon.
    Your fuel economy sounds FANTASTIC. my figuring is this...If you say you get 900km out of your tanks, we assume that you use 110lt of the available 125lt that converts to approx 12.3lt per 100kms. Thats Great fuel figures mate.
    I am getting about 14.5 and very happy with that.
    Next time you fill her up take note of how many kms you have done and how many litres you pump and do the maths. There is a link on this forum that is a converter if you cant do the maths.
    Sounds great mate. And 12,000km old TD42 GOLD!!!
    Cheers and welcome.
    MR
    Jul 2010
    Waterford West Qld
    Hi Wayne and welcome to Nissans Nut House.. Nice toy you have to play with
    Tim
  10. #8
    Welcome to the forum Wayne. Great introduction!
  11. #9
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    welcome to the forum wayne
    cheers roofy
  12. #10
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Top introduction mate. Welcome to the forum
    ________________________
    ______ 2017 D-Max _______
