Results 1 to 8 of 8
Thread: Auto fluid
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    Auto fluid
    I have a 99 4.5 dual fuel in auto, about 250ks on the clock.
    I am wanting to do an oil change for the auto.
    Is it as simple as dropping the oil, changing the filter and filling it back up?
    If so what's the best oil and filter for an auto that's getting on a bit?
    Also does it have a set amount of oil (same as engine oil) or just fill until the reservoir is full?
    Thanks in advance
    Lachlan
    Filter I would always use Nissan, check search engine for what ATF you require
    Expert twisty's Avatar
    May 2011
    ACT
    Go Castrol Transmax Z. Yeah, there is a set amount of fluid, Don't remember how much, sorry. Filter and pan description here.
    GU1 Auto ST4500 lpg/petrol.
  4. The Following User Says Thank You to twisty For This Useful Post:
    taslucas (11th October 2012)
    Aug 2011
    Kellyville, Sydney
    +1 for the Transmax Z. Made a huge difference to my auto behind the ZD30.
    I just drained, popped in & out of drive a couple of times (pumps out a bit more fluid) then refilled. Mine took ~4.5L, but not sure if yours is different.
    Oct 2011
    Quote Originally Posted by Bagheera View Post
    i dont see why they would have different autos for different engines.
    When you where putting it in gear did you have the car running?
    Did you also do a lap around the block then check the level or should it be fine?
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Not sure on Oil capacity on the Gu Box,
    From memory 2 check the oil level, Warm engine up, with engine running run throw gears a few times then re-check level.
    To change the filter you will have to drop the pan, well thats how it is done on the GQ box so assume would be the same.
    I would recommend welcoming in a few new members and downloading the manual, Everything you will need 2 know 2 change the gearbox oil will be in there except the best oil 2 use.
    Todd
  8. #7
    May 2011
    ACT
    Okay ... so I went and looked it up, 8.5l capacity and Nissan recommend ... wait for it ... Nissan fluid (Matic "D"). btw, auto info isn't in the Patrol manual, it's in the RE4R01A pdf.
  9. #8
    Oct 2011
    Cheers guys. i will have to make some time and go and do it now.
