Engine is ZD30, manual GU IV wagon. 3" exhaust EGR blocked and dawes valve set at 17psi.
While driving engine hits about 3500 and shuts down. Releasing the accelerator and re-applying will make power return. No warning lights, just engine power loss for the time your foot is down.
Diagniosis by Hi-Tech diesel was pinched vacuum line at a cost to me of $90.
Still have problem now and is getting worse / more often.
Checked for 'this pinched vacuum line fault' today but couldn't find anything. Connections, plugs & hoses etc all appear good.
If foot is kept flat, engine cuts out between 2000-3500rps randomly. Occasionally plumes of white /grey smoke, but generally engine dies momentarily and then goes again. Almost as if fuel had air bubbles in it.
Boost is at 16-17psi set by dawes valve.
Any ideas as I am stumped
