Results 11 to 20 of 23
Thread: 12000lb generic ebay winch yay or nay
    Jimbeam, you just brought up a very good point, you say you'll only use it a few times.
    Thats a lot of money and weight sitting on the front of your 4x4. I'd personally be putting a locker in the front.
    you may need a suspension up grade as winch combo is 45 kg plus, so theres more fun vouchers gone
    Possibly a 2nd battery as well, all adding up..
  2. The Following User Says Thank You to threedogs For This Useful Post:
    jimbeamteam (10th October 2012)
  3. #12
    The lockers are just gonna get you a little further before you do need the winch! =P
    Tip tap tippity tip tappity tap tap ding dong tipsy topsy wopsy mopsy tippy tap tap tipitty wee
  4. #13
    thats half the fun, coarse you'll still get stuck, but you'll be further in, lol
  5. #14
    And then you need the winch anyway lmao
  6. #15
    Yeah but, yeah but, point taken, just feel its a big cash outlay when there are other options
  7. #16
    Yeah but we all own 4WDs so are used to big cash outlays
  8. The Following User Says Thank You to Winnie For This Useful Post:
    threedogs (3rd October 2012)
  9. #17
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    I was very interested in getting a cheapo winch because I probably wouldn't use it much but then I thought that the cheaper ones probably won't handle sitting around unused as well as a good one. So the time you go to use it, it's probably seized from a water crossing you did 6 months ago. I kept my eye out for a second hand one and got a warn xd9000 for $500. Needs a clean up but at least I know that all parts are replaceable. A quick look on their website showed that every single part had a part number and was available if I needed it. So I have piece of mind that I can keep it for ever and simply rebuild if necessary.:-)
    Tap, crackle, pop
    Hello from Under Down Under!
  10. The Following User Says Thank You to taslucas For This Useful Post:
  11. #18
    brisbane
    True that. Could always get a hand winch ...... Not my cuppa tea but may suit your needs .
  12. #19
    Patrol Guru 89gqpatrol4x4's Avatar
    Brassall
    no matter what winch it is you should be running it in and out a couple of times at least every 4-8 weeks to stop things from siezing up! And at the earliest convenience after a river crossing should run the winch in and out a few times to heat it up and dry out the winch as to not sieze it.
    GQ Snorkle Lockers front n rear
  13. The Following User Says Thank You to 89gqpatrol4x4 For This Useful Post:
  14. #20
    Expert snewin's Avatar
    Muswellbrook, Hunter Valley
    Quote Originally Posted by 89gqpatrol4x4 View Post
    Can you spray some WD-40 or other dispersal agent in there to help? Contact cleaner?
    Love is a TD42T
