Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: LED strip lights for camping
    476 Post(s)
    I have a 5mtr roll of 5050 SMD led's. I want to make up a couple of light sticks to use. Just after some ideas on what to use for the backing. I'm thinking of making them around a metre each with something on either end so they can be hung up horizontally. I'll put in the wiring a little rocker switch so they can be turned on and off with ease too.
    Plus what size wire would be good to use? I was thinking of 3mm twin core or maybe 4mm sheathed twin core for added strength as I would want to make the leads around 5 metres each, maybe longer...
    Thanks.
    Yo Mudski as mentioned before Jaycar sell track to suit these strip lights, plus disfusers and end caps to complete the job,
    Also look at some of the alloy extrusions at Bunnings, might be something there suitable
    Just waiting on the small white switch to arrive, good for inline applications
  3. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    mudski (28th September 2012), zd30elgrande (15th October 2012)
    476 Post(s)
    Thanks TD. Is that switch from Jaycar too? Looks like the perfect thing...
    Nah just something I found on ebay, try these from ABR sidewinder,weatherproof
    That verticle light was just something I was toying with. the wire two core I used is rubber
    awg18 od6mm and $1.70 a metre pt no. wb-1754
    476 Post(s)
    Great. Thanks again. I just found and ordered one of those white switches to try out. Just gotta figure out what kind of strip I will use...
    Expert Irvs's Avatar
    Jul 2012
    Parkdale, VIC
    A bit of 10mm flat aluminium bar from burnings will work great, either that or angle so you can mount it to something aswell. I've done this plenty of times and never had a problem
    1990 Ford Maverick, 4.2 Carby, 2" SL, 2" BL, Dual Batts, 33" Maxxis Big Horns
  8. #7
    This is just to let you now how far camp lighting has come.
    gone are the days of noisey coleman pressure lamps with brittle mantles
    hurricane lanterns just not bright enough' this was one of my first 12v jobs
    you would be surprised how much light this gives out.
    Even 12 v downlights work great
  9. #8
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Awesome looking setup threedogs, where can i get one??? Do they come in other beer flaovours???? what about a bourbon can??? wow the sky is the limit!!! hahahahahahaa
    Hello from Under Down Under!
  10. #9
    Bourbons ones way too expensive, one a budget you know.
    All made from stuff at camp one trip.
    Sort of a frothy, friday idea.
  11. #10
    Aug 2011
    North West Tas
    56 Post(s)
