Results 1 to 10 of 16
Thread: eBay snorkel
    Advanced ns3474's Avatar
    eBay snorkel
    I have purchased a snorkel from eBay ,cheap,was wondering has anyone else purchased one.How they went about the install.
    It came as a full kit with templates and fittings just no instructions
    Cheers Neil
    You may struggle ,if template is not right, there are a few problems with the cheap snorkels.
    not many shops will fit them, so good luck. Maybe a member close by who's fitted one
    may be able to help
    334 Post(s)
    Use the Template but check everything before you cut. It is likely that the template may be slightly out so Measure twice. Set the Template up on the panel and then test fit the snorkel, it should be fairly obvious if they are not in line.
    Be smart and it wont be that hard.
  4. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    patch697 (22nd September 2012)
    thanks for that,i havnt started drilling but everything seems to measure up ,the A pillar looks to be the part that is going to stump me ,they have given me 3 small bolts but nothing to attach them to on the A pillar.
    see how i go
    Neil
    I recently put one of those on my mates Disco.
    Template didnt line up the best for us. The inside part that connected to the filter didn't fit very snug on the Disco so double check that side of things. We had to silicone it shut as there were 2mm gaps and uneven moulding.
    Take some photos for us if can so we can check it out.
    Hardcore healy's Avatar
    south east melbourne victoria
    Yeah templates never work done three now all different brands and run your own pipe off the bit aswell makes it slot easier
  8. #7
    Patrol God wildgu6's Avatar
    Sep 2010
    Adelaide S.A
    mate recently put one of those on his trol,
    We had to silicone it shut as there were 2mm gaps and uneven moulding..
    X2, nothing like the fit of a safari or genuine snorkel. But still does the same job.. As he said, You get what you pay for...
    "Tonka Tuff" 08-GU6, 3.0lt crd, 5 Speed, Turbo Diesel, Hpd, Arb, Ome, MT Baja Atz.
  9. #8
    Still haven't started,I came across the safari fitting instruction off a mate,hopefully I will get to do it in the next couple of days
  10. #9
    fitted snorkel this arvo,started at 330 and finshed at 6,was a little bit fidly but happy with the result
    stoked though all up $42.50 for the snorkel and it looks identical to the safari
  11. #10
    Well done, throw up some photos too mate!
