Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: Split rims & tubes
    WA Wheatbelt
    23 Post(s)
    Split rims & tubes
    Talking about letting air out of tyres with split rims and tubes is a very sensitive issue and not a lot of people are prepared to commit to answer this question, so I won't be offended if you don't.
    Q. Is it safe to let down tyre pressure in tyres with split rims/tubes?
    Q. If you had split rims/tubes and were going beach driving, what pressure, if any, would you let them down to?
    I currently run mine at 45psi. (Cheesecutters)
    Ross
    DX grunt
    Patrol God Finly Owner's Avatar
    Jul 2010
    Waterford West Qld
    Quote Originally Posted by DX grunt View Post
    Ross
    DX grunt
    Ross do run on beach @ 45 or daily press @ 45?
    I would think 30 would be the least you would have splits at. I have only dealt with splits on trucks. And realise they are a problem when relocating lock bead ring in. Once at pressure I have never heard of any problems. But I am new to the $wd use of split rims. So I like you will watch for other replies to see if I am on right track.
    Tim
  3. The Following User Says Thank You to Finly Owner For This Useful Post:
    DX grunt (2nd January 2011)
    WA Wheatbelt
    23 Post(s)
    Quote Originally Posted by Finly Owner View Post
    Tim
    Daily @ 45. Thanks for that. I might have to go and ask a tyre dealer.
    I'm happy with them and haven't had any problems with them. Haven't let the pressures down yet, either. lol
    Jul 2010
    Waterford West Qld
    does your glove box user manual have anything in it for this?
  6. The Following User Says Thank You to Finly Owner For This Useful Post:
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    Mate, I had split rims and used to go to White hills, I'd dump the pressure down to about 17psi, never had a prob. If you go much lower there is a chance that the tyre can spin and snap the valve stem off, then you have a problem. Drive slow and don't overheat the tyre. Cracking wasn't a problem. If you have a spare tube and a compressor and a couple of tyre leavers, you're good ta go.,Tailor are running ATM too.
  8. The Following User Says Thank You to the ferret For This Useful Post:
  9. #6
    Jul 2010
    Waterford West Qld
    Quote Originally Posted by the ferret View Post
    And a steel club hammer to tap bead as well.
  10. The Following User Says Thank You to Finly Owner For This Useful Post:
  11. #7
    Benarkin QLD
    Ive got split rims on the yard hack
    Ive let them right down (pressure unknown)for a wee incident i had,i never had any issues
    Mind you i only drove less than 1/2 a K like this
  12. The Following User Says Thank You to MQ MAD For This Useful Post:
  13. #8
    WA Wheatbelt
    23 Post(s)
    Thanks guys. I've seen a couple of young guys change a split rim in less than 5 mins.
    I've also heard they can be dangerous if you don't know what you're doing - and I don't.
    That's why I carry 2 spares. One for normal and one for Justin Case.
    Note to self. Carry 2 spare tubes.
  14. #9
    WA Wheatbelt
    23 Post(s)
    Nuh.
    From what I can figure out, the Telstra set up was to enable them to go to remote areas, and they took off the originals and put on splits with a 2" OME lift (under all that black undercarriage paint).
    All 6 tyres are split rims, and I'm guessing that if they carried a couple of spare tubes, that should have been enough to get them out of trouble - the equivalent of 4 spare tyres.
    They're relatively easy to take out the old tube and wack in a new one and pump it up...if you know what you're doing.
    Ross
  15. #10
    Sep 2010
    on the coast W.A.
    Allways tap the lock ring to conform to the rim, put a chain or rope around it to prevent the lock ring becoming a missile, put 5psi in and tap tap tap all around and the ring closes right up,
    then inflate to the final pressure, tapping as you go. Face the lock ring AWAY from you when inflating. Folk have died because of flying lock rings, if unsure, don't do it and as you say, carry extra spares.
  16. The Following User Says Thank You to the ferret For This Useful Post:
