Page 37 of 187 FirstFirst ... 3536373839 ... LastLast
Results 361 to 370 of 1862
Thread: MudRunnerTD's GQ From the Ground Up
  1. #361
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by brando4x4 View Post
    Hi mate
    love the truck been following the build on other forums got a couple
    of questions as i want to make a fairlead like yours.
    How thick is the stuff you used for your fairlead?
    Where did you get it from?
    what was it meant to be and how much was it?
    How did you cut it?
    Thanks,
    Brando4x4
    Bumpin this for Brando 4X4
    On a side note.......... for a Tojo driver Danny sure does a lot of work on the Nissan, must mean only one thing....he knows the Tojo won't make it so leaves it at home *L*
  2. The Following 2 Users Say Thank You to NissanGQ4.2 For This Useful Post:
    MudRunnerTD (16th September 2012), Stropp (15th September 2012)
  3. #362
    Rogue Dung Beetle djc123's Avatar
    Oct 2011
    Patch, the lead car on this trip is an 80 on 37s. Nothing broken on that one ;-)
    Its a Toyota! =====> Its a Keeper!! ....... Got an LS2 in it BONUS!! Wish it was Nissan though, Toyotas just can't keep up with the Pootrol pace.
  4. #363
    334 Post(s)
    The lead car just did an air locker line
  5. #364
    Oct 2011
    A torn air line isn't quite the same as a complete cv AND the opposite axle. Thought these Nissan front ends are supposed to be tough.
  6. #365
    334 Post(s)
    We are all bloody limping now! Lol
    I think the group is up to 10 beads off. A Uni, 2 winches, an axle, a CV, a winch rope, a few panels. Damn!
  7. #366
    334 Post(s)
    Sorry Brando I did not see your post before mate.
    It is made from Nylon and I bought it from a plastic place (resiplex) then drilled it in the drill press with a spade core bit then a jig saw will get it done. I then used a bench router to put a radius on all the edges. Easy if you have the right gear.
    The Nylon was not real cheap though to be honest and I probably on saved $50 over buying an alloy hawse fairlead which are an off the shelf item.
  8. #367
    334 Post(s)
    Brando I reckon the nylon is 25mm and it was a blank block
    Here are a couple if pics taken while waiting for the 80 to sort out his air locker
  9. #368
    Banned
    Quote Originally Posted by djc123 View Post
    Mate, this is a Nissan Patrol forum of which im the 2IC so its a better than fair bet im not going to be waving a bloody Tojo flag regardless of who or whats towing it............hahahahahahahah
    Oh... & who's axles & CV's you running Toyota's????.................Bhahahahaha
  10. #369
    Feb 2011
    Shed
    45 Post(s)
    I knew id seen you on tele before Danny, the new Avatar.................of course hahahahahahahahahahahahahahahahahahahahahahaha
  11. #370
    Oct 2011
    Yes. Original Toyota axles and CVs
