Results 1 to 6 of 6
Thread: Replacing my 1990 GQ stearing box.
    Expert Ben89's Avatar
    Feb 2012
    So i've read a few things on the forums about the GU stearing box being an upgrade from a GQ steating box. So I've found these and i'm certain these 2 will do, Could anyone help me out here and make sure I haven't stuffed up anything before I order them?
    http://www.ebay.com.au/itm/290772089...ht_2360wt_1139
    http://www.ebay.com.au/itm/GU-Patrol...#ht_500wt_1414
    Thanks for the help!
    Feb 2012
    Bump, Could someone have a quick look and let me know? I would really appreciate it. Cheers guys
    This one must of got missed mate...
    Finally found the post all about them on the below link which should sort you out...
    http://www.nissanpatrol.com.au/forum...light=steering
  4. The Following 3 Users Say Thank You to AB For This Useful Post:
    Ben89 (19th September 2012), Silver (20th September 2012), taslucas (19th September 2012)
    Feb 2012
    Cheers mate, But theres 2 answers in that thread that I read, was trying to get a clean answer
    Banned
    Quote Originally Posted by Ben89 View Post
    Whats posted in that link above is all correct. The GU power steering box will bolt directly in place of the GQ power steering box with no mods needed to the bolt holes or the power steering lines themselves.
    There is a difference in the taper of the tie rod ends that locates in the pitman arm between the GQ & GU, the GQ being slightly larger of the two. An appropriate adjustable drag link would have to be used when fitting a GU power steering box into a GQ with the appropriate GU tie rod end fitted to the pitman arm end of the drag link & the appropriate GQ tie rod end fitted into the apposing end. When fitting the adjustable Drag link with the appropriate ends now installed, you will need to fit the end with the GU tie rid end fitted to the pitman arm & from the top, not from underneath as it was previous with the GQ power steering box & pitman arm. Fit the other end into the arm attached to the swivel hob in the same way as the original came out.
    I hope this is the type of information your after.
    Best of luck with your mod...
  7. The Following 2 Users Say Thank You to patch697 For This Useful Post:
    Ben89 (20th September 2012), Silver (20th September 2012)
    Feb 2012
    Cheers guys, Appreciate it, Understand now
  9. The Following User Says Thank You to Ben89 For This Useful Post:
    patch697 (20th September 2012)
