Results 21 to 30 of 38
Thread: Moby the white whale super tourer
  1. #21
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    Corner country sounds good. Haven't been to Innamincka. Not sure about the Simpson though. Think I need a bit of sand practice before giving that route a go!
    Should we call the Podders community something so we can have an acronym?
    Eg.
    The PP's (PatrolPodders)
    COPs (Canopies on Patrols)
    CCOPs Camping Canopies on Patrols
    CCCOP Cunning Camping Canopies On Patrols
    POCCs Pod owners Campers Club
    POOP (Pod Owners On Patrols)
    Cuppa
    Love em all
    Macca
  2. #22
    WA Wheatbelt
    23 Post(s)
    I thought Rosco was the Prez, he has been leading the way....Cheers Macca
    Am I ?????
    What about PoP....Pods on Patrols ?????? It is also more age friendly to me.... hahahahahaha
  3. #23
    Beginner twindiff's Avatar
    Jul 2012
    Hornsby Heights NSW
    Corner country and on for me too!
    Yep, Rosco for prez, Cuppa for vice.....
    Cheers,
    Errol
  4. The Following User Says Thank You to twindiff For This Useful Post:
    DX grunt (19th August 2012)
  5. #24
    Ballarat, Vic
    177 Post(s)
    Yep, nothin' like a good bit of vice eh?
    Cuppa. ♨
  6. #25
    Expert GU CAMPER's Avatar
    Sheffield Tasmania
    Hi Errol
    What size tyres can you fit on the modified spare tyre holders
    I have the same obieco ones as you and was looking at changing them so I can fit my 35's on them
    Any chance you can get a close up pic for me
    Cheers Andy
    NEVER USE A SNATCH STRAP ON A TOW BALL AS DEATH MAY RESULT
    GU 2005 Cab Chassis Ex Telstra POD, Set up for Remote Touring and Play
  7. #26
    Jul 2012
    Hornsby Heights NSW
    Hi Andy,
    Mine are 33's, 285/75/16, I simply pulled apart the original Obieco carriers and used the center handle/bolt assembly and added a 5mm round plate to fit the center of the wheel. The plate hole had to be offset from center because of the extra height from the original 7.50 R16's (31's), 2 inches overall but 1 inch at the center of the wheel.
    To use 35's the grab rail above the tyres would have to go (easy) but the trick would be lining up the center bolt/pin that holds the wheel on, it would now be another inch offset. A plate with 2 wheel studs fitted would be ideal or perhaps the mounting points inside lifted to the right height.
    On mine I also added 2 brackets (from the original ladder racks) to the mounting points so that I could also put straps on for that extra peace of mind, after all the whole assembly is held together by the quality of the weld between the bolt and the handle (if the handle snaps off the whole lot falls on the road). It all worked well, 1600 klm's of corrugations to the tip and back and they didn't budge at all. Of course I use R pins (tow bar tongue hitch pins) on the inside of the canopy to prevent theft.
    Hope this helps,
    Cheers,
    Errol.
  8. The Following 3 Users Say Thank You to twindiff For This Useful Post:
    GU CAMPER (22nd August 2012), GUtsy ute (22nd August 2012), Old Wal (28th August 2012)
  9. #27
    Jul 2012
    Hornsby Heights NSW
    More photo's, elec outlet box with merit sockets removed and engel sockets added. 2 x 90 litre poly water tanks. Outback roof console, aftermarket stereo with pop up touch screen and rear view camera and clip on monitor. I have wired it so that when it's turned on it's on all the time (not just in reverse), when it's turned off it still works as well as the original mirror. Time will tell if the mirror suffers premature droop from the extra weight!
    Cheers,
    Errol.
  10. The Following User Says Thank You to twindiff For This Useful Post:
  11. #28
    Jul 2012
    Hornsby Heights NSW
    Shock mounts
    Hi Macca,
    Mine is well covered by the base plate but my shocks are Old Man Emu Nitrochargers. From the front the bottom shock mounts look vulnerable but from the rear it looks like there is only about 2 mm showing of shock stud. Hope the pics help.
    Cheers,
    Errol.
    The best view of the city is in the rear view mirror!
  12. #29
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    Thanks mate mine are a bit beaten up compared to yours, try and get some pics!!!
    Macca
  13. #30
    Hi Twin diff ended up taking my reverse mirror off, was forever adiusting it,way too heavy for a 4x4, in the process of trying something different using multi cameras when I work it out.
    Pic is of a skid plate I made for my last Leaf sprung 4x4. It'll stop your spring hangers digging in on rutted tracks, big holes are for access to u bolt nuts
  14. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    Old Wal (7th September 2012), twindiff (7th September 2012)
