Results 31 to 37 of 37
Thread: Hints to clean the engine bay?
  1. #31
    Feb 2012
    heres a link to Pirahna who sell them...
    http://piranhaoffroad.com.au/index.p...n16q4vckal2f23
  2. The Following User Says Thank You to pjhicks3 For This Useful Post:
    taslucas (8th September 2012)
  3. #32
    Bunnings sell similar items in the gardening aisle - they are hose extensions for old dears to water hanging baskets - put a thinner end on it and it will work wonders.
  4. The Following User Says Thank You to choochie For This Useful Post:
  5. #33
    Feb 2012
    Good Idea - The bunnings one will probably be a bucket load cheaper too!!
  6. #34
    X 2 on the lanolin/lanatec I use it on every thing, even good for your tools, hi lift jack.
    Can't recommomend it enough. Any thing you can find Lanolin is good for camping gear,
    leaf springs, Axe heads, if you can name it you'll find lanolin will protect it.
    WARNING:::: be carefull when using on battery terminals, allow it to dry. MAY CAUSE A FIRE
    Spray on decking it stops termites even, best stuff ever
  7. #35
    brisbane
    Quote Originally Posted by pjhicks3 View Post
    You can buy a thing made by "Staun" called a massojet or something like that, and it just hooks up to your hose - no pressure washer needed, and it has a long handle, I have one, and it works a treat for this..
    I had one of these and wouldn't recommend them the fitting on them are cheap and mine lasted about a year, I'm just glad I got the cheaper one with out the compressor fittings
  8. #36
    Jul 2012
    Pottsville
    hey 3D does the lanolin stay sticky [its wool fat isn't it?] would beach sand stick to it?
    3lt GU 111 Wagon 2 inch lift,3in Taipan exhaust, cross country intercooler,catch can,EGR blocked, dawes and needle valve,Pyro/boost gauge ARB lockers,steinbaurer chip, long range tank, s/s water tank, draws, warn winch, and other stuff.
  9. #37
    Jul 2013
    good tips guys, cheers
