Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 83
Thread: Gay horn
    Expert snewin's Avatar
    Muswellbrook, Hunter Valley
    For those stebel nautilus hobbies would you use a relay or just the existing wiring for one of the existing ones.
    Had one on my motorbike a few years back and forgot all about them. Great little units. Might be just the thing.
    Love is a TD42T
  2. #22
    Second Massive vote for the power of the Stebel!! Got one on the GQ and need to fit one to the GUIV. They are very small and easy to fit anywhere not like the big triple horns and easily as loud
    Check out this great vid most of you have probably seen but i blast the horn at the end! Its a Stebel and Its at least 100m away from the camera
    Here is the link - Cheap as Chips!!
    Stebel Air Horn
  3. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    patch697 (4th September 2012), threedogs (3rd September 2012)
  4. #23
    Quote Originally Posted by snewin View Post
    Relay for sure but power the relay from your factory horn supply. From memory it might even come with a relay.
    I mounted mine of the top of the inlet manifold above the fuel pump behind the power steering pump
  5. #24
    Thanks MudrunnerTHATS WHAT I"M TALKING ABOUT I've been after a very loud horn that was compact as well, this ticks all the boxes.
    Will probably mount it inside the wing of the bullbar, plenty of room. Look forward it fitting it now.
  6. #25
    Mine came with the relay. I got the 300hz one, not the dual tone one.
    Tappa tappa
  7. #26
    Thanks for the link. Just ordered one for Gertrude. Will definitely make her sound more manly.
    Love is a TD42T
  8. #27
    Make HER sound more MANLY. what the!!!!!!!
  9. #28
    Gertrude is L-O-L-A Lola's big sister.
    Love is a TD42T
  10. #29
    She was a show girl and nows she's a he, did I get that part right?
    I'm confused, didn't think Patrols were gender specific, then again I call mine NEV
  11. #30
    Mine's definitely a girl. A big one. She doesn't have camel toe, she's got moose knuckle.
    Love is a TD42T
