Results 1 to 10 of 11
Thread: 4.2 Petrol ?
    May 2011
    4.2 Petrol ?
    I am thinking about buying a Patrol with 4.2 Petrol engine and a auto. Is there some issues in this engine that i should know about? And also how is the gas mileage?
    Gas mileage sucks.
    Auto's have issues with overdrive or slipping when left over night cold.
    They have headgasket failures.
    Have the above thoroughly tested before purchasing and they can be a good reliable thing with regular maintenance and servicing they have been known to do more then half a million k's.
    My cousin's manual TB42S did 600,000ks before he sold it a couple of months ago and the only engine work it had done was a new head, they are prone to failure at around 250,000ks and costs a couple of grand.
    Gas mileage isn't great, I get 21L/100kms from mine.
    Expert Irvs's Avatar
    Jul 2012
    Parkdale, VIC
    Just recently purchased a TB42s mate and have been told some things to be wary of are head gaskets blowing or heads cracking (knock on wood), this is very often because people never adjust their tappets so the tolerances get out of whack and allow hot gases to stay in the head thus causing the head to say bye bye. Another thing to be aware of is the steering box at around 200-300 thou, they get sloppy and there tends to be a lot of play in the steering at 100k's. The auto trans is apparently 3-4k to rebuild, it's a complicated piece of gear and as a result can cost a kings ransom to fix.
    Try this blokes website particularly the 'Buying a GQ' section. Very helpful
    http://www.gqpatrol.com
    1990 Ford Maverick, 4.2 Carby, 2" SL, 2" BL, Dual Batts, 33" Maxxis Big Horns
    Quote Originally Posted by Irvs View Post
    Ask Taslucas about that.
  6. #6
    Benarkin QLD
    Expensive to run, yes 20-25 L/100 Ks is about the norm
    Head failure/head gasket issues , no better or worse than any other alloy headed engine
    People dont use the correct coolant or if any and this can cause issues
    The radiators get blocked , with in proper use and age and can cause them to overheat,again no different to any other unserviced or maintained rig
    Buy the absolute best of the best you can find or afford
    I spent well over 6 months looking for my TB42 auto,ill jump in it and drive round australia tomorrow
  7. The Following User Says Thank You to MQ MAD For This Useful Post:
    patch697 (24th August 2012)
  8. #7
    Expert GQPorkroll's Avatar
    Hunter Valley NSW
    I have a TB42 5 speed dual fuel patrol. It has extractors and I recently fitted a 350 Holley to it, it is by far the best 4WD i've ever owned. Personally, I wouldn't go for an auto but that is just personal preference, however its a very torquey lazy motor, mine doesn't rev over 3000 rpm under normal driving, so unless the auto's are very strong, I imagine they'd be prone to failure, with the stresses put on them, at least a clutch can slip.
    My truck has about 500,000 on it, I'd say its had a freshen up once in its life because its pretty lively and isn't smokey. I wouldn't have any hesitation firing it up and driving it anywhere I needed to go.
  9. The Following User Says Thank You to GQPorkroll For This Useful Post:
  10. #8
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Quote Originally Posted by GQPorkroll View Post
    The autos are tough as nails. They may fatigue after a long time like any other part. A standard TB42 auto fitted with a Nomad heavy duty valvebody is strong enough to take more than three times the power of the standard engine. They are used extensively in 4wd racing applications such as the outback challenge, winch challenge etc, and can be found behind all sorts performance engines.
    Hello from Under Down Under!
  11. #9
    RIP - valued member and true gentleman of this forum that will be missed by many! Silver's Avatar
    Feb 2011
    Brisvegas
    like all autos, attention to keeping it cool is important.
    "As a boat owner and a four wheel drive owner I feel like a pelican: every where I look I see a big bill in front of me”
  12. #10
    Beginner Nozzle's Avatar
    Logan
    I recently bought a TB42 looked fine runs great oil was clean when i bought it drove it for two weeks cream in the sump.
    The blokes chemiweld must have let go.
    still runs perfect im just not driving unless i have to until it gets a head job.
