Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: A/C light globe replacement
    Legendary Alitis007's Avatar
    15 Post(s)
    No dramas mate we'll wait till then..
  2. #12
    Maudsland Queensland
    Unhappy Don't waste your time
    I don't know why you would even bother to change that stupidly dull light.
    It is almost impossible to see if it's on or not in the daylight.
    The best way to check is to feel if the switch is in or cycle it.
    The only time I can ever see it clearly is on a dull day or at night.
    Don't waste your time and effort.
    It's like a few little annoying Nissan foibles another is that they still only have one reversing light , must be that we are only allowed to back into things on the right side because the left is nicely illuminated.
  3. #13
    Expert the godfather's Avatar
    Mar 2011
    Piara Waters, WA
    Men are bright as Rod. But my A/C one died recently as well. So I am following with interest as well.
  4. #14
    Brisbane South West
    For me it's a matter of if it ain't broke don't fix it. In this case it's broke and I want it fixed.
  5. #15
    Advanced thepunter1's Avatar
    Wheelers Hill, Melbourne
    Check this out it should help you.
    Aircon Bulb Replacement
    And this one;
    Bulb
    Regards,
    David.
    GU 2006 Cab Chassis
    Don't try to teach a pig to sing it frustrates the pig and wastes your time.
  6. The Following User Says Thank You to thepunter1 For This Useful Post:
    daggy (28th August 2012)
  7. #16
    Am following this one closely as well. I actually wanted to change up the colors if could.
  8. #17
    Coffs Harbour at the moment but queenslander origanally
    I found similar globes at jaycar and replaced my ac, was a little fiddly but easy enough, way brighter too so i replaced reticulation globe aswell. will get a pic for you when i get a chance. might even be able to get the jaycar part number.
  9. #18
    recirculation*****
  10. #19
    Expert scotty83's Avatar
    Apr 2011
    Hillcrest, QLD
    Quote Originally Posted by roobs View Post
    It would be great to have the part number
    Scotty B | Take it Off Road or Take it Back
    3.0L GUIV 2005 - TIG Welded Intercooler, NADS, Redarc Dual Battery, Additional rear power socket, 2" Lift (Ironman constant load foam cell), Electronic Trailer Brake Controller, Steel Bullbar, 12,000lb Winch, UHF
  11. #20
    Perth WA
    I just did all mine with 2mm leds blue from ebay. Jaycar sell them as well. Only prog was pulling switch apart and squeezing a resistor in there as well
    2004 GU ST 3.0 DDi 2" Tuff Dog Lift, Warn 9000lb, Custom dual Batteries Redarc, Safari Chip + Snorkel, 3" exhaust, NADS, MBC, DIY can, PWR Int,+9" fan, 7" GPS-DVD-TV Igo8 and Ozi with 2cams,6.5" Kicker splits and 6x9", Pillar+ Racetech EGT-PSI, Heated seats, fixed compressor, Arduino dual battery and engine/OAT temp display, 3" Projected 50W HID's with halo DRL's........so far.
