Results 1 to 10 of 20
Thread: LSD Problem
    Expert nickpeacock36's Avatar
    Oct 2010
    North Lakes Qld
    LSD Problem
    Hi All
    My LSD has stopped working. I dont want a locker in the rear so i need to get it tightened. Does anybody know of a reputable specialist around the North side of Brisbane? also has anybody had this done already and if so, what should i be paying?
    I wouldnt mind having a crack at it myself if i can find somebody to guide me through it.
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Hi mate, might be obvious but have you checked the fluid quality and level?
    Hello from Under Down Under!
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    x2 that was my first thought as well
    Oct 2010
    North Lakes Qld
    I changed the oil recently to Penrite Limslip 140. I filled it to the correct level (until it started to come from the fill hole) Is that oil ok?
  5. #5
    Yep thats fine. You can either shim it up, machine the housing or completely rebuild it. Darren Boxsell at redcliffe seems to be alright for this kind of work. If your good at reading and following instructions can quite easily be done at home.
  6. #6
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by nickpeacock36 View Post
    im not sure on that oil but this is reconmended
    gear oil hypoid l.s.d part number kld31-14002
    sae 140 and %10 volumefriction modifier
  7. #7
    Oct 2010
    North Lakes Qld
    thanks for the info. I can follow instructions ok. Is there a good set somewhere? Also when you say rebuild, what parts do you need?
  8. #8
    Oct 2010
    North Lakes Qld
    Quote Originally Posted by roofy View Post
    Thanks.
    I guess the 140 in the part no is a good sign i used the correct type then.
  9. #9
    As long as its for a limited slip and has atleast an 85w-90/140 then it should be fine. I run castrol 85w-140 lsx oil in mine with no issues. There is a good set of instructions on another forum im on with photos i will try and track it down. As for the rebuild you could get away with just doing the clutch pack in the LSD
  10. #10
    TRAFALGAR VIC
    35 Post(s)
    would be good if you could find it make interesting reading thats for sure
