Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: Rubbing noise from rear wheel , tricky to diagnose , any thoughts?
    Hi Again , took truck to mechanics on Thursday when the noise promptly disappeared only to come back again on Friday - So we pulled axle out on Saturday to investigate - bearing had lost some grease but not all - So elected to replace seal at this point as we don't have access to a press at home but .........
    Whoops - got the wrong seal in my spares kit - so bearing re packed and repeat again with new seal in the week .
    Apologies if this is getting tedious - more exciting posts later......and thanks for help .
  2. #22
    Hi again , just to round off this saga - pulled axle shaft out again and replaced with correct seal ( $13.80 online ) repacked with grease etc . Seems to be OK but a bit hard to tell in 90 km winds we had yesterday !
    Decided not to go to drama of removing bearing at this point though good to know spacer can be a problem . I'll keep an eye/ ear on it and see how I go . If I find something definite in the future on this I'll post a note but in the meantime thanks for all the helpful comments and advice.
    Patrol Guru Morton's Avatar
    Sydney West
    Malcolm, tedious is good, this helps others out that are not so determined as you are, so many issues have the same noises/problems etc that it is often hard to know exactly what the issue is, trial & error is par for the course with some problems, but the experience gained today will help someone on here in 6 months when they fall to the same drama, you may point them straight to the REAL issue, this saves time & in some cases buckets of money, absorb the knowledge & part with your wisdom as required
  4. The Following User Says Thank You to Morton For This Useful Post:
    malcolm (12th August 2012)
  5. #24
    X2 with above, with threads like yours the forum can only get better, well done and fingers crossed you solved the problem
  6. The Following User Says Thank You to threedogs For This Useful Post:
  7. #25
    Patrol Guru White Elephant's Avatar
    Sep 2011
    Perth,WA
    Eggzachary. All the info helps everybody out mate. Pleased it was a reasonably simple fix.
    95 GQ RX RD28T LWB Wagon and stuff. www.levelsevenband.com
