Results 1 to 7 of 7
Thread: Which Tyre Size is best
    Feb 2012
    Mandurah, WA
    Question Which Tyre Size is best
    Fitting new rubber to the Patrol. Present tyres are 275/65R17, rims 17 x 8 with 10mm offset and 2" suspension lift. Looking to fit Cooper ST-Maxx but their only 17" rims sizes are 265/70R17 & 285/70R17
    My two questions are;
    1/ which size is best ?
    2/ will the 285's cause reduced clearance?
    Will be very thankful for opinions & advice.
    Coogs- 2009 GU Y61 Patrol 3L-CR, OME 50mm, 3" exhaust, ARB B/ bar, Warn Winch, ARB compressor, Snorkel, UHF & Barrett HF radio, Red Arc Dual Batts, Bushskinz Bash Plate, Cargo Barrier, F/R Recovery Points, Dual Pillar Pod (Pyro & Boost), ARB Rack, LR Tank, Chipit & EGR blank, Water Watch, Drifta Drawers, ARB Reversing Camera, IPF Lights, ARB Awning, GVM upgrade, Front Locker & other touring mods.
    Go the 285s mate, I presume you have a GU....... you've got plenty of space in those wheel arches to take larger rubber plus it will give you a bit more diff clearance
  3. The Following User Says Thank You to Clunk For This Useful Post:
    Coogs (12th August 2012)
    North brissy
    x2 285's or 33's basically the same size probably the most used and best size really for a patrol.
  5. The Following User Says Thank You to nissannewby For This Useful Post:
    Hawkesbury, NSW
    Hi Coogs,
    I just had the Cooper ST Maxx 285/70R17 tyres put on my 2012 GU today, and they feel great on the road and do fill out the wheel arches nicely giving the car that nice beefy look with out being extreme.
    John B.
  7. The Following User Says Thank You to John B. For This Useful Post:
    Coogs (29th August 2012)
  8. #5
    Feb 2012
    Mandurah, WA
    Hi John B. .... Thks for your response. I'm matching Patrol & camper (2011 Tvan Murranji) wheels and tyres. Have the 285's had any efffect (reduced?) on your suspension clearance?
  9. #6
    Advanced Steveo_the_Devo's Avatar
    Oct 2011
    Wollongong NSW
    Hey John, if you don't mind saying, what price did you get the Coopers at?
    2011 CRD with a bunch of stuff bolted on
  10. #7
    Hawkesbury, NSW
    Hi Coogs & Steveo_the_Devo, my sincerest apologies for not having responded to your questions sooner gentlemen. This is the first time I've been back on this forum for a while.
    Coogs I found a little bit of scrubbing when I had the steering at full left look but had no effect on the suspension other than the tyres giving me a little bit of additional lift. I recently had a full 2" OME suspension lift done and I get no scrubbing at all and very good suspension clearance.
    Steveo, I actually traded the original tyres over on the car when I first bought the Patrol. From memory, I think the tyres were about $450 each fitted and balanced, however I only paid $300 per tyre.
    John
