Results 1 to 10 of 16
Thread: Converting A GU 4.5,3.0,2.8 to td42
    Feb 2011
    Shed
    45 Post(s)
    OK I'm putting a flame suit on I imagine some Q and U guys will be ready to give me what for.
    Orighty here goes. Agatha's body is starting to look not quite as sexy as when she was a young girl......soooo an upgrade of sorts will need to take place in the next 12 mths i rekon.It seems you can get a 4.5 GU pretty cheap but i dont want petrol. I want my TD42 still and my lift and my locker and my 5spd. Can such a conversion be done and if yes whats involved. Am I better off looking for a 2.8 or 3.0 for a conversion. I havent totally dismissed looking for another Q with a good body, but i kinda want something a little bit bigger, and i figure its gunna be the same amount of work either way. Ive been going hard on the search button the last couple of nights but cant find anything definitive or detailed enough to help me decide. Ive got a complete troll as a donor engine mounts etc g/box cross member. I'm in a state of confusion I love me tuff N ruff as guts Q, but gotta do something.
    Aug 2010
    adelaide
    hey growler what about getting a gu with a blown 3lt motor i rekon you could get it at a good price
    if you want some help to do the conversion let me know and i can give you a hand
    ps hows the chillies im ready for them
    stephen
    OH LEATHER IS NICE
  3. The Following User Says Thank You to my third 256 For This Useful Post:
    MudRunnerTD (2nd August 2012)
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    Kat's GU is for Sale. It is a 4.5 and Auto.
    Plenty of Power and Comfort. Now that you are getting up in years you will need your comfort RAFLMAO
  5. The Following User Says Thank You to Bob For This Useful Post:
    growler2058 (2nd August 2012)
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    I choose to ignore this "growlers" fellow from now on......
    Lmao
    Most the time it sounds like the issues that arise from putting a TD42 into a rd28 or zd30 are that the gearbox and diff ratios aren't suited to the TD42. Youll have the whole lot there to change over so I'm guessing it should match up?
    Is there any extra computer loom type stuff that the GUs have?
    How could you cut up Agatha?
    Tap, crackle, pop
    Hello from Under Down Under!
  7. The Following 2 Users Say Thank You to taslucas For This Useful Post:
    growler2058 (2nd August 2012), Winnie (2nd August 2012)
  8. #5
    334 Post(s)
    Hey Growls,
    Mate my understanding is that you will have quite a bit of trouble getting your car certified as a TD42 if you do a conversion in a GU.
    I understand that your engine MUST be out of a Newer car than the car your putting it into?? Regardless of the fact that the GU came out with a TD42 i am not sure if you will slip through the cracks or not bud?
  9. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  10. #6
    Yeah wake up to yourself just buy a a nice late model straight gq with a blown up 2.8 and convert it like i did lol.
    http://www.nissanpatrol.com.au/forum...-conversion-gq
  11. #7
    Patrol Guru White Elephant's Avatar
    Sep 2011
    Perth,WA
    Quote Originally Posted by 97_gq_lwb View Post
    x2..go the mighty Q!
    Although, I had to rebuild my blown up 2.8...But she's still going!
    95 GQ RX RD28T LWB Wagon and stuff. www.levelsevenband.com
  12. The Following User Says Thank You to White Elephant For This Useful Post:
  13. #8
    As with mudrunner the motor going in needs the same emission as required for that year on the motor coming out. So thinking the earlier the GU you buy the cheaper and easier it may be. You'll need to convince the powers that be that pollution is set up correctly
  14. The Following User Says Thank You to threedogs For This Useful Post:
  15. #9
    Feb 2011
    Shed
    45 Post(s)
    Hey Growls,
    Something i need to check. We do get it fairly easy in SA with rego requirements. I was thinking Early early GU when did they loose the silver top td42, anyone know?
  16. #10
    Aug 2011
    The 2.8s use a gearbox out of a 350z. (Smaller box). The 3ltrs are the same box as 4.2s but have a dual mass flywheel instead. Also slightly different diff ratio, but nothing a set of 33s or 35s won't fix... 2.8s I believe are basically different from box back...
  17. The Following User Says Thank You to guterra For This Useful Post:
