Results 11 to 20 of 33
Thread: Got it !!!!! and have a few questions...
    Hardcore jack's Avatar
    Ballarat Area
    26 Post(s)
    Let me know if you have any issues with the GPS, I had some fun using it and the dealers couldn't tell me what the issue was.
    Still laughing at the 'solution' to get it working.
  2. The Following User Says Thank You to jack For This Useful Post:
    Ronin (27th July 2012)
  3. #12
    Jul 2012
    Hobart Tasmania
    Hay Appolo what issues you having, i have a full sup instruction direct form eclipse to unleash all the potential of the unit.
  4. The Following 2 Users Say Thank You to WogsRus For This Useful Post:
    MudRunnerTD (27th July 2012), Ronin (27th July 2012)
  5. #13
    WA Wheatbelt
    23 Post(s)
    My suggestion is to open the glove box and get out the Owner's Manual and read it! lol
    You might actually learn something. hahaha
    Congrats and take care out there.
    Rossco
  6. The Following 2 Users Say Thank You to DX grunt For This Useful Post:
  7. #14
    Rossco
    Don't be such a woman Rossco, real blokes don't read manuals!!!!!!! Hahahaha
  8. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    DX grunt (27th July 2012), Ronin (27th July 2012)
  9. #15
    Nice lookin trol you have there ronin
  10. #16
    Ballarat Area
    26 Post(s)
    Hi WogsRus,
    It's actually quite funny, the search function only worked intermittently. Even took it to the dealers, two salesmen couldn't get it to work either. Ended up booking it in for the 1000k service and they were going to have a look at the issue as well. Turned out to be any easy fix - it only works when the handbrake was on!
    And that's not in the manual, I checked. Had me scratching my head for a while.
    Certainly be interested in the instruction set you have.
  11. The Following User Says Thank You to jack For This Useful Post:
  12. #17
    WA Wheatbelt
    23 Post(s)
    Don't listen to Clunk. He drives a KISS GQ. hahahaha
  13. #18
    Expert Ronin's Avatar
    Brissy
    For the 1000 service do you take it back to the same dealer u bought it from or go to a preferred dealer..
    Also which dealer in Brissy got decent service ?
    2012 GU Patrol Simpson Edition. Auto. UHF, Bull Bar, 2" lift with Koni shocks, dobinson coils. 3" stainless Steel Exhaust.
  14. #19
    Expert Blacklotusdog's Avatar
    As others have said the skids is the stability control, push the car to hard on the dirt and it detects if it starts going side ways and cuts your power, feels bloody wierd when it kicks in, works well from my experimenting though, turn it off and you can do donuts to your hearts content.
    The diff lock is the round switch on the right hand side of stereo, for reference you can only engage the diff lock in low range, pretty sure low range will automatically turn of the stability control as well.
    If you want to get some better performance out of those IPF spotties have a look at HIDdownunder.com, bloke there does HID conversion kits for them in 70w, will set you back about $250 but will turn them into flame throwers.
    Check your Fuel gauges, do yours show full tanks when you fill up, mine show well under full on both sub and main, some guys show way over, few blokes have had there instrument clusters replaced under warranty because of it. ill be getting mine looked at when i get a chance but nearest dealer for me is 250km away and i have already heard from other patrol owner up here that they are bloody useless.
    2012 GU8 Polar White Auto ST Patrol, Factory Bull bar, Scangauge 2, EGR blanked, Milford cargo barrier, Outback ideas recovery points, Micks retrofit HID 3 inch projectors with Osram bulbs and 55w ballasts, GME TXE3420, Sidewinder dual battery with monitor, Windcheetah 2.0m alloy rack, Suspension Stuff 2" Flexy lift with SS Monotubes, MT ATZ 4 ribs 265/75R16 on black Dynamic rims, Custom rear draws with fridge slide.
  15. The Following 3 Users Say Thank You to Blacklotusdog For This Useful Post:
    jack (27th July 2012), MudRunnerTD (27th July 2012), Ronin (27th July 2012)
  16. #20
    Oct 2011
    Ronin, re your question on running in, suburban traffic is, funnily enough,probably the ideal environment. The engine tends to be used in a variety of rev ranges, rather than a constant cruising speed, without being heavily loaded. The other advantage of this is that the transmission and driveline parts are given a chance to work harden. This theoretically means you'll have an ultimately more reliable vehicle than one stressed heavily from day 1, although with modern machining tolerances and practices being what they are the necessity for this has been reduced.
    07 DX CRD Auto Wagon
  17. The Following 2 Users Say Thank You to GRA.GU For This Useful Post:
