Page 6 of 22 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 211
Thread: XR6T into GQ conversion
  1. #51
    Hardcore
    central coast nsw
    Quote Originally Posted by Bigrig View Post
    You've more than tweaked my interest mate - will be watching and applauding as you go!
    Don't do it bigrig, you haven't run in the one you have now !.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  2. #52
    Couple of Comp trucks down here in Mexico, were pulling 14 sec 1/4 mile times, getting around 235 kw at the back wheels , running 37" centipedes, could smoke all 4 at 60kph, awesome to watch, yours would be similar I would think. good luck with the build. Motors were 4.8 turboed nissan jobs. enameled blocks huge amount of work on motors.
  3. #53
    Hardcore
    central coast nsw
    Vids please, we all want to see this, please please please please please please.
  4. #54
    Expert twase's Avatar
    Campbelltown NSW
    Mounting the ICC
    Started to mount the ICC into the GQ. Looks like it will fit and clear the gear sticks just fine..
    Change of planes out with the low series ICC and in with the premium ICC.
    1990 Ford Maverick LWB - BA XR6T powered.
  5. #55
    North brissy
    Mate this is awesome love how you are grafting all the falcon gear into the trol the gauge cluster looks factory and the icc looks great too will be tops when its done
  6. #56
    Definitely taking it the extra mile, should all be worthwhile in the end mate good luck with it all.
  7. #57
    Comp trucks even spun all 4 going to Wandin one year on the freeway in the wet, will see if They have vids, scared the heck out of a few hoons
  8. #58
    Campbelltown NSW
    Started to mount up the bellhousing today and guess what, it has a few issues.
    First as I already suspected I have around 6mm of interference between the crank and the gearbox input shaft.
    Next the slave cylinder needs about 10mm or so spacing out to line up with the fork. Might try using a BA clutch slave and see how that goes. (Edit: closer to 15mm out and moved forward about 15mm also)
    The bellhousing fouls the firewall on a starter mounting tab on the bellhousing that is not even needed, I was tempted to grind it off but moved the firewall out of the way a little.
    Lastly and the worst bit is the BA starter won't go all the way home into the bellhousing, it fouls the inside of the casting. looks like the CNC had a spell while it should have been doing this bit....Rang Dellow but no answer on a Saturday.
    Can't say I wasn't warned about Dellow.
  9. #59
    lol dellow you could piss a pattern in a sandpit and get a better casting.
  10. #60
    Campbelltown NSW
    Pity the are the only ones that make this bellhousing.
