Results 1 to 10 of 10
Thread: Twin thermo install
    Expert patrol2.8's Avatar
    Nov 2011
    vic
    Twin thermo install
    Started the twin thermo conversion on my 2.8 have removed the clutch fan and my son has made up the alloy shroud will be using twin thermo set up out of the EF-EL Falcon plan is to have them setup so they come on automaticly but have a switch/s in the car so they can be switched off for water crossings etc
    Theres only one thing tougher than my truck............. YES DEAR GOING TO DO THE LAWNS NOW
    WARNING: Towballs used for recoveries,can and do kill people and damage property
  2. The Following 2 Users Say Thank You to patrol2.8 For This Useful Post:
    iht2670 (22nd April 2012), NissanGQ4.2 (15th April 2012)
    Nov 2011
    vic
    cut the holes and the fans mounted have sealed all around the fans and got the wiring in place and most connected will fit all the hoses and fill the system with coolant in morning and give it a test run
  4. The Following User Says Thank You to patrol2.8 For This Useful Post:
    Nov 2011
    vic
    Ok job finally completed except for the cab switches as for power gains didnt really do anything to brag about except it seems a bit smoother
    temp sits where it always has well under half have orderd a temp gauge for it so will be fitting that in the next couple of weeks
  6. The Following User Says Thank You to patrol2.8 For This Useful Post:
    HammerBuilder (21st April 2012)
  7. #4
    Looks the goods mate! Hoping to do this to my td42 soon
  8. #5
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Where do you have your temp sender located? Any pics?
    Top job, I really need to put a descent shroud around mine!
  9. #6
    Nov 2011
    vic
    Ive got the davis graig adjustable temp sender unit the sender slides into the top hose with the controller mounted near by it you can see the controller in a couple of the pics i think i have the fans coming on a bit early waiting for the tempgauge to arrive so i can install and set them to the correct temp my son made the shroud for me he makes a lot of the things i need for it best thing about having a boiler maker in the family
  10. The Following User Says Thank You to patrol2.8 For This Useful Post:
    HammerBuilder (13th July 2012)
  11. #7
    Expert HammerBuilder's Avatar
    Lismore, NSW
    Nice work on this 1 as the ol' 2.8 could always do with a bit less stress on it as does mine so now your thread has got me thinking !!!
    Cheers TonyD
    Got the baby GQ a 1997 2.8TD RX Wagon Racetech EGT & Boost Guages Dobinsons coils 32in BFG KM2 M/T
  12. #8
    Nov 2011
    vic
    Hammer builder I enjoy modifing the truck if you do something like this remeber to throw up some pics
  13. #9
    Nov 2010
    canberra
    how did you brace the shroud?
    when I looked at doing a similar thing I was advised to take it to a fabricator to get it stamped to provide some rigidity....
    90 GQ DX Shorty
    89 Maverick LWB
    http://tinyurl.com/gf0012-aust-Gallery
  14. #10
    Nov 2011
    vic
    Quote Originally Posted by gf0012-aust View Post
    G`day one of the pics above shows how we the braced it if i did it again though i would put about another 10mm between the shroud and the radiator to allow just that little bit more airflow
