Results 1 to 10 of 19
Thread: GU ST - is vibration common
    Jul 2012
    Brisbane
    Just checking if there is a common known problem with GU ute having a vibration through the steeering at 90 K's /hr
    Expert scotty83's Avatar
    Apr 2011
    Hillcrest, QLD
    Yes this is common. search steering vibration/shaking. Most report this at about 80km/h. Seems to be a Nissan factory fitted drama. I have found it is worse with my GUIV Alloy rims than my steel ones.
    Scotty B | Take it Off Road or Take it Back
    3.0L GUIV 2005 - TIG Welded Intercooler, NADS, Redarc Dual Battery, Additional rear power socket, 2" Lift (Ironman constant load foam cell), Electronic Trailer Brake Controller, Steel Bullbar, 12,000lb Winch, UHF
  3. The Following User Says Thank You to scotty83 For This Useful Post:
    BradWill (9th July 2012)
    Jul 2012
    Cairns
    Yes I've noticed around 80km/h, very slight but still there. (GUIV steel rims)
  5. The Following User Says Thank You to Pup Patrol For This Useful Post:
    What style tyres are you running????
    Apr 2011
    Hillcrest, QLD
    Cooper AT3's in my case 265/70/17
    sure they're balanced right? ,as at a 4x4 shop, might take a bit of vibration out, some shops and tyre places are lazy and wont deflate the tyre on rim and rotate it 180 deg to see if they can get it better. mud tyres are a nightmare
  10. #7
    Jul 2012
    Brisbane
    Thanks for this info- have just passed up purchasing a mint condition GU due to this. Owner said he was never able to fix. Does anyone know a cause or fix.
  11. #8
    Jul 2012
    Brisbane
    not sure - only took it for a test drive - but just standard rims and road tyres
  12. #9
    Jul 2012
    Brisbane
    do you know of any cause or fix. What can make it worse?
  13. #10
    Loose wheel bearings plus tyre out of balance it all adds up
