Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: ZD30 catch can
    ZD30 catch can
    Hey guys any recommendations on where to buy an oil catch can for a ZD30 Patrol?
    I bought one from an ebay seller but I'm not happy with it and the bloke I'm fitting it for wouldn't be either. Do you generally plumb them back into the engine or just use a drain tap?
    Cheers all.
  2. The Following User Says Thank You to spannaman For This Useful Post:
    Spider1 (23rd December 2017)
    Provent is the main choice, info on this elsewhere
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    provent 200 is best as for plumming thats your choice
    i went for the drain op on mine and depends how long and close the
    cat con is to the sump
    Aug 2010
    adelaide
    Quote Originally Posted by roofy View Post
    x2 just buy the provent can $170 dont buy the extras then go to super cheep or similar to get the pipes and fittings
    a hell of a lot cheeper
    stephen
    OH LEATHER IS NICE
    Beginner KING LING's Avatar
    Jul 2012
    Mansfield , Victoria
    I've got a Cross Country 4 x 4 anti grenade kit ( catch can ) looks good , great workmanship , easy to install , good price and havený had any probs with it
    Thanks guys I will look into these. Got a 3" mandrel exhaust so no cat converter in the way, but I would prefer to plumb it to make it maintenance free as it is for someone else not me.
    Provent? can I find these on the net? Cross country I know of this truck has one of their intercoolers on it, beautiful workmanship.
  8. #7
    TRAFALGAR VIC
    35 Post(s)
    try www.westernfilters.com.au just buy the can and plumb your self
  9. #8
    TRAFALGAR VIC
    35 Post(s)
    about 170 bucks
  10. #9
    Unafordable
    4 Post(s)
    The important part is to consider which ZD30 Patrol you have as onwards from GU4 version the engines no longer have the hole in the block for the drain to be connected as the previous versions. So in that case the alternative methods of draining the Provent needs to be figured out.
    It's a GUIII so the hole should be there. I have got the Cross country kit with the Dawes valve in it and it looks to be the goods. will be fitting it in a few days once I finish putting the GU TD42T into the GQ to make some workshop room. Thanks everyone for their advice and information.
