Results 1 to 10 of 12
Thread: Cav fuel pre filters, yes? or no?
    Oct 2010
    Old Bar, NSW
    Today I decided to change my fuel filters, mine is a '05 4.2 TD.
    The standard filter has a genuine Nisson product fitted, and I also use a CAV prefilter.
    The ute has travelled 26000 klm since the CAV was installed and the Nissan was replaced at the same time.
    The CAV is before the Nissan filter.
    Take a look at these...
    #1 Both on the bench
    #2 CAV
    #3 CAV close up, note sludge
    #4 CAV side view
    #5 Nissan side view
    I am suprised at the filth on the CAV and how clean the Nissan one is.
  2. The Following 2 Users Say Thank You to macca For This Useful Post:
    AB (1st April 2012), nissannewby (2nd April 2012)
    The proof is in the pudding aye.
  4. The Following User Says Thank You to nissannewby For This Useful Post:
    macca (27th March 2016)
    Aug 2011
    Not exactly sure what it proves. If the CAV is first in series, then I would hope it would capture more.
    Or is your point that it lets something though?
    Me: ditch the Nissan filter and change the CAV more regularly - they're cheap enough to do it every 5000 and still be in front.
    Oct 2010
    Old Bar, NSW
    Quote Originally Posted by GeeCee View Post
    Not sure if it proves anything.
    And I have no point, only put the thread for discussion.
    My observations are;
    The CAV has a lot of crud in it, did it come from the fuel or my fuel tanks?
    The CAV filter caught a lot of the rubbish, the Nissan looked to be fairly clean therefor did the CAV do a good job? or not?
    Do you think the Nissan filter was a good backup?
    Did I leave it too long between filter changes?
    Do I replace the CAV more frequently?
    If there was only the Nissan filter would it have let an amount of fine contaminants through to the pump / injectors?
    What would have happened if they were the other way round?
    Lots of questions, and hope some answers here will be of value to myself and others.
    CAV cost about $7.00 Nissan $50.00 maybe change the CAV at each oil change and leave the genuine longer, a good point.
    I will still leave the Nissan in circuit as it has the water alarm, my CAV is a cheapy without the alarm.
    Cheers Macca
    I would leave both filters fitted. I would just change the nissan filter every second service and the cav at every service. Could be from the tank could be a bad batch of fuel could be a number of things. Keep the 2 filters and you shouldnt have to worry about it getting much further than the second filter.
  8. The Following User Says Thank You to nissannewby For This Useful Post:
  9. #6
    Oct 2010
    Old Bar, NSW
    I think you are on the right track there nissannewby, think this will be added to the maintenance schedule.
    Was thinking 10k for the CAV and 20k for the Nissan.
    Interested to hear what others do.
    Cheers Macca
  10. #7
    I would go 5 and 10. The biggest killer of injector pumps is contaminents. Being a diesel fitter myself I change all filters every 5k they are cheap both my 4.2's get done every 5 and both still on standard pumps.
  11. The Following User Says Thank You to nissannewby For This Useful Post:
    macca (2nd April 2012)
  12. #8
    Expert janderson's Avatar
    Bearii Vic
    If it works for you, keep doing it.
    1st G60 Then MQ Now GU
  13. #9
    Nov 2010
    WOW i asked this question in another post this is amazing and what i thought would be the case.
    you might find the black sludge is a diesel bug it might be worth treating your tank to a fuel additive
    I hear a brand called fuel keen is good but i have never used it I have used chemtech diesel power you can buy it from any repco store at around $15 a bottle 250ml
    Hope that helps you a bit
    Brendon
    2008 GU walkabout 3L auto wagon, 2" lift, Nissan winch bullbar, Ironman winch, Roo lite spotties, Scrub bars & side steps,Ferret rear light bracket with two Led work lights.My tip, Always carry a good well stocked in date firstaid kit when 4wding medical help is always to far away.
  14. The Following User Says Thank You to bushytas For This Useful Post:
  15. #10
    SHELLHARBOUR
    I installed a CAV filter/separator to my hilux in 1994, after a bad batch of fuel blocked the fuel pick up in the tank at 20,000km (i removed the in tank sock as it would not pass the black gunk)
    the vehicle has now done over 300,000km, I changed the OEM filter at 200,000km as it was starting to rust on the outside, (I live on a dairy farm and the vehicle is always mucky from the cows droppings)
    have always cleaned out the CAV every 5,000km since fitting it and always find a small amount of black sludge and some grit in the bowl, the black sludge and grit come from the local servo, if I see the tanker in the bay I try to wait a day before filling up to avoid as much as possible fuel from a stirred up tank
    regards
    Joe
    PS have also fitted the CAV filter separator to my GUDX , Pajero and tractor for same reasons
    2010-DX Patrol Dual Cab Chassis, Front LOKKA, 3500kg GVM, 4.8 front brakes! (now stops like it should!), 4.625 Diffs (now drives like it should) 35"Mud tires, 3"exhaust, Rear air bags
  16. The Following User Says Thank You to JoeG For This Useful Post:
