Results 1 to 5 of 5
Thread: LPG in radiator?
    Nov 2010
    Sydney
    LPG in radiator?
    Here's a new one.
    Mate has a GQ with LPG, last few weeks, after a long trip, the coolant fills the overflow bottle and leaves air in the top of the radiator. When the radiator cools it doesn't draw the coolant back in. When you open the radiator it lets out air under pressure and is low on water. Had it checked out by radiator place, found all to be well. Last trip we took both our GQ's just in case, sure enough it did it again. When I opened the radiator cap I got a distinct smell of LPG, mate couldn't smell it. Seems to me the gas mixer is leaking LPG into the coolant andforcing the coolant into the overflow bottle, is this possible?
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    I have never heard of it, but just did a search and found this: http://www.squaredarches.com/phpbb2/...php?f=7&t=1215
    So I'm guessing it is very possible
  3. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    zmaster (14th June 2012)
    Gladstone
    Sounds like a blown head gasket to me. Fill the radiator and run the engine with the cap off. Look for bubbles in the top of the tank. Best not have a fag while you do this one.
    Nov 2010
    Sydney
    First thought was blown head gasket, but only blows bubbles on LPG, was so tempted to put a match to the air in the radiator, just to satisfy curiosity. LOL.
    Perth WA
    Yes very possible as the converter uses the hot rad water to convert the liquid lpg to a gaseous state.
    2004 GU ST 3.0 DDi 2" Tuff Dog Lift, Warn 9000lb, Custom dual Batteries Redarc, Safari Chip + Snorkel, 3" exhaust, NADS, MBC, DIY can, PWR Int,+9" fan, 7" GPS-DVD-TV Igo8 and Ozi with 2cams,6.5" Kicker splits and 6x9", Pillar+ Racetech EGT-PSI, Heated seats, fixed compressor, Arduino dual battery and engine/OAT temp display, 3" Projected 50W HID's with halo DRL's........so far.
