As of mid April 2012 body lifts do not have to have Queensland Transport Approval given first. They can now be Approved by an Approved Person, under the K3 Code.
Must comply to below:-
50mm maximum lift
Body blocks must be same diameter as original
High Tensile bolts must be used
Blocks can be steel, alloy or high density plastic or poly
All gear lever boots must be retained and floor sealed
Brake lines & clutch lines to be routed correctly
Good workmanship to apply
Airbag sensors to remain operative as per manufacture design
Body cuts can now be complied by an Approved Person without seeking prior approval from Queensland Transport. A K3 plus other codes will/could be required such as LK1 and if needed a LO1.
If I can be of any assistance regards vehicle modifications please give me a call on 0418 745 830 or drop me an email.
Regards
David Metcalfe
Approved Person 2868
  Reply With Quote Originally Posted by Rocklobster
