Page 32 of 1057 FirstFirst ... 3031323334 ... LastLast
Results 311 to 320 of 10561
  1. #311
    Feb 2011
    Shed
    45 Post(s)
    Got pi55ed off trying to bleed brakes. Snapped off the bleed nipple for the brake proportioning valve. got a flat bettery all pointing toward a fubared alternator (gotta love Loveday) :-) took the bark off me knuckles somewhere in the process, now charging the battery so i can get to work...........JOY
  2. #312
    NE Victoria
    Fitted the new fridge slide that goes with the Engel 50th aniversary gold plated bling edition fridge, started on the wiring install for said fridge, measured up the space that will hold the redarc battery isolator in order to make a mounting plate and thought about where I am going to install the new Ryco fuel/water seperator element to run inline with the existing water seperator. I hate water in me diesel!
  3. #313
    Advanced JamoGQ's Avatar
    Pulled the spigot bush out with a bolt and paper towel. Works a treat.
  4. #314
    Western suburbs of Melbourne
    11 Post(s)
    Got a 2" lift kit quoted KONI shocks and spring $2200.00
  5. #315
    Started running more wires, reverse light, in cab winch controls, re do the reverse camera. Isolator override switch and aux battery control.
    Got half the dash apart and wires every where. Had a mate over to lend a hand, not sure if he was a help or hindrance!
    Teno's Troll...
    08 CRD ST. 2" lift, 33' Maxis Bighorns, Snorkel, ARB Deluxe Bar with Foggies, 12000lbs Avenger Mako TDS with Synthetic rope.
  6. #316
    Nasty Dog - Moderator Woof's Avatar
    Perth WA
    63 Post(s)
    Got 4 wheel nuts to replace the locknuts that I butchered with the hammer and cold chisel two weeks ago and best of all I bought one of these...
    [IMG][/IMG]
    [IMG][/IMG]
  7. #317
    Nelson Lakes, New Zealand
    Started work on the roof basket for the Safari, making it big and strong 1.2mx2.4m and 250mm high the bottom trayu is made out of 34mm pipe 3mm side wall and 50x50x4mm steel mesh. The top frame is 25mm pipe with 2mm side wall and 200x250x3 mm plates to join the two togeather
  8. #318
    Advanced Bad-Trol's Avatar
    South Hedland, WA
    Started installing new custom rear barn door drop down 'work/prep' table. 800x350mm ally plate. Not sure if I'm going to vinyl the underside or leave it, only time will tell.
    Here's a quick photo
    Bad-Trol: 2004 GU3 ST-L. Sent from my iPhone
  9. #319
    South Hedland, WA
    Also replaced the bonnet gas struts and these ones are POWERFUL! Need two hands to close her now!
    No more bonnet falling on my head when working on the donk
  10. #320
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by The Dogman View Post
    just 1?!?!
