Results 1 to 7 of 7
Thread: td42 fuel gauge is not working
    whats some things that could be the problem wich i could fix it to get it working again??? any help would be much appreciated.
    Legendary timbar's Avatar
    Feb 2011
    perth
    Gday Zac ...Welcome to the Forum ...Please put up an Introduction in the Introduction section Tell us a little about yourself and your Patrol you will get a better response from the forum members and Im sure someone will be along soon to help you out with your problem.
    Again Welcome
    Tim
    1989 GQ LPG / PET TB42 LWB WAGON 4'LIFT 33's
    WELCOME TO THE MUD PITT WE DRIVE NISSAN PATROLS
    Check the sender they fail
    Advanced jazza's Avatar
    sa
    is it on empty or just stuck on last reading? it could be the float in the tank could be stuck worn?
  5. #5
    Expert Bubba's Avatar
    Jul 2012
    Central Coast NSW
    i have the same issue with mine, it is stuck midway and the previous owner said that it had been that way for years
    how difficult is it to pull out the tank and check the float and senser?
  6. #6
    Feb 2011
    Brisvegas
    GQ wagons with TB42 have a port through which the sender etc is accessible, in the floor of the load space. No need to remove the tank etc
    I bet the the TD42 GQ is the same, but don't know for sure.
    Pull up the carpet and have a look?
    "As a boat owner and a four wheel drive owner I feel like a pelican: every where I look I see a big bill in front of me”
  7. The Following User Says Thank You to Silver For This Useful Post:
    Bubba (3rd August 2012)
    Yes gq td42's are the same setup.
    Lift the carpet in the rear remove a panel with 4 screws then you can access it.
    assuming it is a wagon .
  9. The Following User Says Thank You to 97_gq_lwb For This Useful Post:
