Results 1 to 10 of 11
Thread: p40 engine info
    Beginner Dave.79's Avatar
    Busselton. wa
    p40 engine info
    would like to hear from any 1 that owns or has owned a patrol with the mighty petrol 4.0
    Patrol God Finly Owner's Avatar
    Jul 2010
    Waterford West Qld
    Quote Originally Posted by Dave.79 View Post
    I haven't but I hear they are awesome and rare.
    Tim
    Busselton. wa
    Yeah they are mate the only other 1 ive seen running was in an old forklift!
    Benarkin QLD
    The P40 sixes their in the G60s arent they ???
    Busselton. wa
    yeah thats rite mq ...
  6. #6
    Jul 2010
    Waterford West Qld
    Quote Originally Posted by MQ MAD View Post
    They were also released in Some MQ's, but very rare.
    Tim
  7. #7
    Rural Goulburn
    I have a G60 with the P40 engine and it is one of the better 4wd engines that I have driven. It will pull away from 100 rpm and can be idled over a rock at that speed. almost imposible to stall and awesome internal inertia for poping up that rock face.
    I had to fit a holden carby for the steep stuff as the original Nissan kept overfueling with the nose well up. the holden does as well but not as much. The combo of the small bore and long stroke gives usefull torque at bugger all revs, Put a chalk mark on the flywheel and play with the idle screw and you can count the revs by eye. (doesn't charge the battery much at those revs though)
    As mentioned elsewhere I now have a couple of MK's with the L28 engines and am strugling to get usefull low torque and subsequently keep stalling them. The LPG engine needs 1000 rpm to get going wheras with the P40 starting off at idle throttle and 400 rpm was a doddle.
    IMHO the L28 was a very poor choice for the MQ/MK . The L28 is just too undersquare. --Nice engine , loves to rev, great for the skyline, but wrong for the MK. A revamped P40 would have been much better. I am contemplating a transplant.
  8. The Following User Says Thank You to Crankshaft For This Useful Post:
    misha1973 (16th March 2013)
  9. #8
    Benarkin QLD
    Quote Originally Posted by Crankshaft View Post
    The L28 MQ/MKs dont have anywhere near the torque of the turbo diesel , and the P40s have more torque again
    But the L28 will out rev both,and do it all day
    Ive got both the turbo diesel and the L28 and on the same rather steep river bed, the little L28 has to scream to pullout, but the diesel is just over idle
  10. The Following User Says Thank You to MQ MAD For This Useful Post:
  11. #9
    Apr 2011
    Melton
    Extrac:-
    The P40 is the least common engine, although it is known to be a power-house (compared with the L28). It is a refined version of the engine found in the older 60 series Patrol. The P40 is a 4.0 litre straight 6, fueled by a 2-barrel carburetter.
    It produced 114 HP / 85 kW power @ 3600rpm (DIN) and 200 ft-lb / 270 N·m torque @ 2000rpm (DIN).
    The p40 in the 60 series is not the same motor as the P40 in the MQ
    I belive the mining industry pushed nissan for a bigger motor as they where not happy with the L28.
    I have read a post about someone from NZ efi his P40 Using a meagsquirt setup) - big increase in power.
    My rb30 (carby) is rated at 100kw with 220 Nm and it goes a lot better the my old L28
  12. The Following 2 Users Say Thank You to GQ TANK For This Useful Post:
    Crankshaft (21st June 2012), misha1973 (16th March 2013)
  13. #10
    Feb 2013
    SA
    just bought a ute mk p40? how rare is that???
