Results 1 to 6 of 6
Thread: GQ engine swap
    May 2011
    GQ engine swap
    Anyone ever changed a 4.2petrol engine for a similar diesel in a GQ? My petrol engine with 213,000kms is still strong and works beautifully off-road, but is REALLY, REALLY thirsty.... Like I'm getting 2kms per litre on sand in high range!!!! Any advice, suggestions would be welcome - for example would I have to change the gearbox and tranny? Thanks guys
    Last edited by K9mutley; 29th May 2011 at 12:03 PM. Reason: Spelling mistake - should read GQ engine swap
    Hi mate, fixed the title for you.
    Welcome to the forum, don't forget to post up an intro about yourself in the introductions section.
    Ive never done it personally but the only advice I would give would be to get a donor 4.2 diesel car.
    See the link below for a bit more info mate...
    http://www.nissanpatrol.com.au/forum...ghlight=rossco
    Arnhem Land top end of the NT
    Auzzy1
    Check out Ebay guy up in Queensland has holley carb conversions big bucks but at around $2.00 a litre for unleaded should be worth the expense thats the way I am going too chase fuel economy
    CHEERS Auzzy1
    5 Post(s)
    i was going to do it then backed into a tree so i bought a diesel. tbh i rekkon its too much effort
    Expert HammerBuilder's Avatar
    Lismore, NSW
    If your mech minded anything is possible
    From previous reading gearbox & transfer & tailshafts are same configuration, you'll have to use the diesel clutch, bellhousing & engine mounts
    then theres little things like wiring, Air con, & exhaust conection all in all it can be done but up to you if you have the time tools & patience
    Cheers TonyD
    Got the baby GQ a 1997 2.8TD RX Wagon Racetech EGT & Boost Guages Dobinsons coils 32in BFG KM2 M/T
  6. #6
    Beginner dion_83's Avatar
    Jul 2011
    I've looked into it a bit with my Mav, It's a 4.2 auto and loves to consume fuel. From the info I found the deisels aren't that much better. I got good results from a few thing the best was when installing the snorkel I did away with the factory intake ducting and factory cleaner as they flow like S&*T, and the exhaust heats the duct which inturn heats the air passing through it, I ran new ducting over the front of the rocker cover and it stay's very cool and got a massive improvement especially on the hiway.
