Results 11 to 20 of 22
Thread: Lifted GQ wagon suspension set up. Please help :feedback:
    Expert Richo460's Avatar
    Cairns, QLD
    ok so i got a pic, its pretty dodgy but its all i have as i'm not at home.
    Can anyone recognise from the pic if i need or have drop boxes or lowerd arms?
    I don't have sway bars, that is prob making it feel worse too.
    Thanks for all the help fellas!
    If you going through hell...Keep going
    GQ wagon locked - lifted - 33's, 02 SS ute, XB coupe 460bb, KTM530
  2. #12
    Feb 2011
    Shed
    45 Post(s)
    Foter?? Where?? Hahhahahaha sorry mate aint no piccie there
    Tappin N Crappin
  3. #13
    Cairns, QLD
    might help if i post the pic
    ok so now i actuall know what drop boxes are, i see that i have them.
  4. #14
    Feb 2011
    Shed
    45 Post(s)
    Yup drop boxes for sure
    Tappin N Crappin
  5. The Following User Says Thank You to growler2058 For This Useful Post:
    Richo460 (14th May 2012)
  6. #15
    Cairns, QLD
    so from the info i have is that it has drop boxes, 4" lifted coils, 5" lifted tought dog 45mm adjustable shocks, superior eng radius arms and superior eng adjustable panhards. running 33" bighorns. Looks like there is no sway bars.
    Maybe a wheel alignment is needed and then just suspension tweaking?
    I have bought some new door hinges and bailey channel to hopefully stop a few door and window rattles, that might make it seem a bit better over bumps.
  7. #16
    Feb 2011
    Shed
    45 Post(s)
    Mate the rattles and clunks are just her whispering sweet nothing's in your ear ;-)
    Tappin N Crappin
  8. #17
    Cairns, QLD
    well i put a set of 6x9's and a 12" sub in her before i came back to work and that seems to have fixed alot of the rattles and other noises.
  9. #18
    North brissy
    There are no sway bars pictured and you still have standard radius arms. I think you may have meant superior lower control arms on the rear? And your certainly running drop boxes. With your rattles etc just jump under there and make sure everything is tight.
  10. The Following User Says Thank You to nissannewby For This Useful Post:
  11. #19
    334 Post(s)
    Yep definitely got Drop Boxes. Where the radius arm attaches to the front diff looks a little strange? can i get a close up pic of that?
    As newby said, you dont have a front sway bar connected or attached at all. Not that big a deal. The front radius arm looks to be a Nissan one right up until i look at that front connection. a closeup please.
    If you do have drop boxes and some other form of caster correction too then you could be over corrected that wont be helping either. It will steer like a boat.
  12. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  13. #20
    in the bush
    hey bud iv always ran tuff dog shocks they tend to be more rigid and rough unless there worn out then they tend to start floating around i would be checking the bushes in your lower control arms what run under the bottom of your diff common for them to be flogged out causeing the diff to move around upsetting everything. also check the rear lower trailing arm bushes as they wear and the back diff floats around and maybe steering dampner setup wrong or worn out.
  14. The Following User Says Thank You to nissanluvr For This Useful Post:
