Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Lifted GQ wagon suspension set up. Please help :feedback:
    Expert Richo460's Avatar
    Cairns, QLD
    Ok so i just picked up my GQ that i bought unseen off ebay wasn't sure what i was gonna get. I paid 7k for an early wagon TD42 with 400k's, front air locker, warn winch, 4" lifted with tough dog shocks and superior eng goodies, uhf, quarter chop, recovery gear, dual battery system and monitor and 33" muddies. I was pretty happy and it seems to be pretty good, just a few spots of rust and in need of a turbo.
    Anyway apon driving it home from bris to cairns the ride was horrible, very very bumpy. When i finally jumped under to have a look i found that the shocks were adjustable and were set to fully hard
    So i backed them off to about half on front and rear and a few more minor adjustments up the road. Now it has 5" lifted tough dog 45mm bore shocks and i think a 4" spring lift with all the superior engineering bits but it seems to go from super bumpy to wanting to wander over the road.
    It doesn't get up the shakes but just seems to like wandering over the road which is not great. I mean its not way scary, just a bit unsettled. I can't see anything loose underneath when doing the steering wheel wobble check so i'm wondering if there is something else i should be looking for or adjusting. Wheel alignment seems to be good as it doesn't pull left or right.
    For the lift it has i would definately think it should handle the road better but i haven't driven any other Q's with similar lifts. Has anyone had experience with the tough dog shocks or suspension set up in general?
    Thanks in advance.
    If you going through hell...Keep going
    GQ wagon locked - lifted - 33's, 02 SS ute, XB coupe 460bb, KTM530
    334 Post(s)
    So when you say wander do you mean your forever correcting the thing cause it seems to be very twitchy and slight steering?
    If this is so then your caster correction is not up to spec for the lift and you dont have enough caster correction and your Toe-in is killing you.
    When the guy did the 4" lift what did he do in the way of caster correction? Caster bushes? Caster Plates? or Drop Boxes? Or Arms?
    Get a set of Drop Boxes for it mate and you will never look back, That Wander is very exhausting when driving long distances cause you have to be On It all the time to keep the thing straight.
  3. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Richo460 (7th May 2012)
    Cairns, QLD
    Ah ok. I am not sure what he did and if i had a look i wouldn't be able to tell. It has alot of good gear under there but maybe nothing done with the caster correction. Thanks for the info, i will get it to a suspension shop one of these days for some attention. The more i soften the shocks the worse it gets to drive, hopefully i can find a happy medium.
    Thanks MudrunnerTD
    334 Post(s)
    Take a Pic of the front diff where the Radius arm connects to the front diff (The arm that goes from under the front seats to the underside of the front diffs and holds them forward) and also the back connection of these same arms and i will likely be able to tell you what they have done. Easy fix mate but your best bet is to be armed with the answers when you go to a suspension mob or be prepared to bend over You dont need New Suspension you just need to tickle her a bit.
    Cairns, QLD
    Thanks heaps. I will have to get the GF to take some pics as i am about 20 000 km's from home, this could be interesting.
    I am still learning the names of the arms and stuff under there but i do remeber that the radius arm is a superior engineering one, but no idea what has been done where it connects onto the diff.
    I just reckon it should be able to handle bumps on the road alot better, it still to rough but floaty at the same time, and i have been in other lifted 4bies that handle a shitload better and are no where near as rough. Is it possible the springs are too soft, would a stiffer spring and softer shock setting be better?
    North brissy
    My 5" lifted GQ kinda floats but i have medium load flexys and adjustable tough dogs with superior super flex arms in the front . My tyres (which im not happy with) for on road use make a difference to my ride. If its floating as your saying i would be looking to see if it has sway bars or not as this will make a difference. Castor incorrection will prob cause more vibration, twitchy steering etc than harsh ride. Tyre pressures can play their part in this as well. I wouldnt change the springs but possibly look at another set of shocks which may be valved better for what you do
  8. #7
    Expert bordertech's Avatar
    Bordertown
    Quote Originally Posted by Richo460 View Post
    Thanks in advance.
    On a lifted rig bump steer is increased and poor wheel alignment will do that, also springs that are too soft.
    I love terra firma - the less firma the more terra
  9. #8
    Cairns, QLD
    I have the very early GQ (88) and it doesn't have the sway bar release like the last gq i had but sold. Comew to think of it i'm not sure it even has sway bars at the moment, def will get the missus to send me some pics. I only just bought the rig but surely no one would take out the sway bars, the bloke claimed he did very little off road stuff as he lived in the city.
    Thanks for the replies, suspension is not my thing.
  10. #9
    Feb 2011
    Shed
    45 Post(s)
    Mine is a pov pack 90 model and did not come with a front sway bar. I haven't put my rear sway bar back in after a 4" lift as I'm lazy and haven't bought extended sway bar links. However the ride is quite good not as you describe yours anyway. It's a little bit rolly around roundabouts
    Tappin N Crappin
  11. #10
    Advanced Mojo01's Avatar
    Adelaide, South Australia
    Quote Originally Posted by growlers71gq View Post
    yup and those bastards keep putting em in, driving over them is fun though
    I am spending my children's inheritance on my 92 GQ PATROL .. and by the time they get it, it will have way to many kilometers on the clock, and it wont be worth anything
