Results 1 to 10 of 19
Thread: diff oils
    Expert luvpsi's Avatar
    diff oils
    hey guys i have searched but no answer
    im doing my huib seals this weekend and wondering what diff oil to use in my GQ patrol diffs.
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Hey mate, im doing the front diff this weekend. I also did a search but i found what i was looking for......recomended 80W-90 in the front diff (no locker).
    It did say what to use for the back but i cant remember......Youll have to have another go at searching. Put in difff+oil and it will be there somewhere. Goodluck
    Hello from Under Down Under!
    North brissy
    80w-90 for the front and i use 85w-140 lsx in the rear
    Heres a good write up on maintenance and oils etc
    http://www.nissanpatrol.com.au/forum...ve-Maintenance
    Copied from above post
    DIFF OIL; front - 90w hypoid rated gear oil. Rear - 85w140 limited slip hypoid gear oil.
    Front 5.4 litres, rear (LSD)2.1 litres (factory locker)3.0 litres,** H260 4.7 litres.
    **H260 rear diff fitted to most manual GU 3l, 4.5l and 4.8l Patrols.
  5. The Following User Says Thank You to 97_gq_lwb For This Useful Post:
    dhiren_motilal (11th April 2015)
    So the front doesn't need LSD oil but the rear does
    yep unless you fitted an lsd to the front lol
  8. #7
    North brissy
    Yeah mate. I use 80w-90 in my g/box, transfer and front diff and 85w-140lsx oil in the rear diff. It is possible to fit an lsd out of a path finder into the front of a gq.
  9. #8
    yeah i dont want to go that far of changing diffs etc im using gulf western top dog in my crankcase and finding it great and was thinking of using the gulf western gear lube 80w90 in the diff as i find all there products good and cheap what do you think
  10. #9
    North brissy
    Yeah it should be fine check your owners manual it will give you the oil spec for it then just double check your oil of choice matches
  11. #10
    will do thanks guys
