Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: themostat...??????
    x2 on using genuine thermostat as well.
    I was in a rush and bought a Repco one before a trip and it played up big time. Sometimes jammed and didn't open and they also opened up at 80 degrees rather then the standard 76.5 on a GQ TD42 and I had a lot of overheating issues. Never had that with the original thermostat so go the genuine!
    Also with a thermostat stuck open or not having one can cause problems with your engine not reaching It's ideal running temp too.
  2. #12
    hi guys..its GlenG's wife here (((waves)))
    he is going mad ...he has gone to shop and was given a thermostat for the patrol and its round shape and the part that u have told us to take off is a square shape hole ..it the same in your pic Roofy..so how does a round thing go in to a square hole..
    please help as he is sooooo pissed off atm...
  3. #13
    oh just found out that the patrol is a 2001 nissan turbo Gu zd30 ...is the thermostat housing is a different spot in the motor..
  4. #14
    Quote Originally Posted by GlenG View Post
    sorry mate cant help ya, I have a petrol GQ, hopefully one of the GU ZD30 owners will be on soon to help
  5. #15
    Feb 2012
    I was flicking through the ZD30 manual and remembered this thread.
    The thermostat is located where the bottom radiator hose enters the rear of the front gear case. There is an alloy section that the rubber hose attaches to. Hope this helps
  6. The Following User Says Thank You to Fity For This Useful Post:
    JoseM (28th March 2012)
  7. #16
    Advanced cairnsGU's Avatar
    Jul 2011
    Thermostat is located on the passenger side of motor
  8. #17
    Aveley (Perth)
    I think the thermostat might be in the lower hose where the connection bolts to the motor
  9. #18
    Beginner Tymeup's Avatar
    Mt. Morgan, Queensland
    G'day all,
    Don't mean to hijack but........I'm gonna hijack for a sec. Do thermostats travel well as spares? As in, thrown in a box with all your other spare bit n' pieces.
    Cheers.
    Ty.
    2000 4.2 - 2" Lift - 3" Exhaust - IPF Spotties - Kincrome Winch, Plasma Rope - Stratos Seats - BF Muddies - Procomp Wheels - Trailblazer Fridge - Outback Drawers - Solar - Running with 2Stroke and a truck load more to come..........(Chopped in July)
  10. #19
    Thermostats will travel well in the box where they came in.
    Since the thermostat has been fingered here as the culprit, it might also pay to inspect the radiator fan as it also plays a very important role in cooling the engine.
    Is the overheating situation occuring when the engine is idling in stop start traffic? Or is it overheating when on the highway?
    If the former, then the radiator fan's viscous coupling needs to be inspected to see if it is engaging properly when things are getting hot under the hood.
    '09 Toyota Land Cruiser 200 Series GXL diesel
    '99 Land Rover Discovery II V8 auto
  11. The Following User Says Thank You to tempestv8 For This Useful Post:
    Tymeup (30th April 2012)
  12. #20
    Wodonga
    I saw the photo further up and screamed no!!!!! Wrong side. Any way I hope it all fixed and working for you
